Current software version of radio
Old Feb 24, 2013 | 10:17 AM
Pmutalik2000's Avatar
Pmutalik2000
Default Current software version of radio
Is there any way to find out what the current version of software is installed in the 130 RES radio? I found an update from about 6 months ago, but I just got the uconnect installed in my 2012 grand caravan SXT. So before I try the update I want to make sure it is newer than what is already installed. Unfortunately I don't have any of the manuals. Bought the car used.
Old Feb 24, 2013 | 11:35 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
yes u can its pressing the menu button then in one of those system info be there. you have the version of gracenotes, system nav if u have it, and other info too.
Old Feb 25, 2013 | 08:24 AM
xsdbs's Avatar
xsdbs
This is only true if you have either the RBZ or the RHB touchscreen radio. On the RES, the only way to get the SW version is to have the dealer use the scan tool to pull it.
Old Feb 25, 2013 | 08:25 AM
xsdbs's Avatar
xsdbs
Where did you find an update for the RES radio? Do you have a link to it?
Old Feb 25, 2013 | 09:54 AM
Pmutalik2000
Xsdbs, thanks for the response.
I got the link from a message you had posted 0n 06-04-2012 Here is the message
"For those with 2012 vehicles that have either of the following radios:
RES, REQ, RBZ, & RHB
The File for the TSB 08-018-12 Uconnect SW update can be found at the link below:
http://www.mediafire.com/?vedk6f30v84e95r "
The message goes on to include the instructions...
Here is the link to your post
https://dodgeforum.com/forum/audio-v...sw-update.html
Old Feb 25, 2013 | 10:00 AM
Pmutalik2000
xsdbs,
So if I use this udpate and the radio has newer software in it will it refuse to update the radio or will it blindly accept an older version?
Old Feb 25, 2013 | 02:45 PM
xsdbs's Avatar
xsdbs
Ok, just a little FYI (and others also)
The RES, REQ, RBZ & RHB radios have an external Uconnect module. Unlike the 730 & 730N which have an internal Uconnect system.
With the above mentioned radios, there are separate SW versions for the radio and the external Uconnect module. The Updates that I have listed in those links are for the Uconnect module only, not the radio.
Now if your vehicle was built after 1-1-2012 then you have the most current Uconnect SW version, if it was built prior to that date then you'll want to perform the update.
xsdbs,
