2010 Grand Caravan - Ticking from transmission plug every 10 seconds
Old Mar 21, 2013 | 10:03 PM
junker's Avatar
junker
Default 2010 Grand Caravan - Ticking from transmission plug every 10 seconds
2010 Grand Caravan, 3.8, Auto, 110k Miles
My wife says it is 'shifting a lot' and revs when she slows then proceeds. I hooked up my laptop and found no stored codes or freeze frame data.
I was trying to figure out how the heck to check the transmission fluid when I noticed noticed that there is ticking noise every 10 seconds from the engine bay. Using my trusty $5 mechanics stethoscope I tracked down the ticking is coming from an electrical connector on the front of the transmission.
A photo of the ticking connector is attached.
So, I seek advice on the ticking noise and the shifting problem, perhaps they are related?
Much Appreciated
Attached Thumbnails 2010 Grand Caravan - Ticking from transmission plug every 10 seconds-2013-03-21-21.37.25.jpg
Old Mar 22, 2013 | 11:02 AM
junker's Avatar
junker
Ok, I have determined that this plug is for the Solenoid Pack. So the ticking noise makes sense that it is a solenoid actuating. Question is why?
Basically I need help determining which way to go. If I knew it was the solenoid pack then I would replace it myself. But what if it is something else causing the solenoid to actuate, like low fluid or a sensor somewhere. I wish there was some trourbleshooting information on this.
I found a 62TE transmission manual here but it just has parts replacement steps:
http://www.scribd.com/doc/112608066/...ESSURE-CONTROL
Anyone have any troubleshooting info?
Old Mar 23, 2013 | 12:29 AM
master tech's Avatar
master tech
Site Moderator & Tech
When you hear the ticking sound, is the transmission in park or in gear?
Old Sep 24, 2023 | 07:57 PM
Tido546's Avatar
Tido546
mine is in park just sitting there at idle
