Fast Coolant Leak Between Engine & Tranmission ???
Old Apr 20, 2013 | 07:48 PM
dorough's Avatar
dorough
Default Fast Coolant Leak Between Engine & Tranmission ???
My 2004 3.3L Grand Caravan sprang a leak - a rather fast one... 2-3 cups per minute. The coolant is coming out from the lower part of the engine where the block mates with the transmission. There's a little "slot-like" area there where the transmission extends lower than the block. It's not leaking at the top of the engine. And I can't see all the way to the back side to see if it's running down from back there somewhere. (I kind of doubt it, but not sure.) Any ideas? Thanks in advance!
Old Apr 20, 2013 | 11:23 PM
steak59's Avatar
steak59
probably a freeze plug leak. Will require removing the Transmission to gain access.
any picture so we can give better advice?
Old Apr 21, 2013 | 01:40 AM
master tech's Avatar
master tech
Site Moderator & Tech
Also check the heater hose going to the intake manifold and the rear head gasket.
