wow
Old Jul 14, 2013 | 01:53 PM
cpttuna's Avatar
cpttuna
Default wow
Situation: the 97 caravan(3.3 engine) has not run in 18 hrs. I open the rear hatch with the key to take something out. I leave the tailgate up and continue to walk pass the van. As I pass the front of the van, the wipers start up and make 4 complete cycles stopping halfway up the windshield. Any ideas????????
Old Jul 14, 2013 | 02:12 PM
Cougar41's Avatar
Cougar41
Are you a Zombie?
Ghost wipers are a common problem sometimes caused by a weak battery, stalk switch or BCM. Inspect battery connections for corrosion. Disconnect negative battery cable to reset the data bus.
Old Jul 14, 2013 | 10:19 PM
cpttuna's Avatar
cpttuna
Battery posts have been cleaned. BCM PCM and wiper motor have been replaced. I do not believe battery is weak.
Old Jul 14, 2013 | 11:50 PM
master tech's Avatar
master tech
Site Moderator & Tech
Have the battery load tested and also check the IOD fuse in the PDC. this also causes the wipers to go on.
Old Jul 15, 2013 | 04:37 PM
cpttuna's Avatar
cpttuna
replaced battery and IOD fuse is OK. Tried wipers. They do not come on.
Old Jul 15, 2013 | 11:41 PM
master tech
Good job!
Old Jul 16, 2013 | 01:07 AM
Cougar41's Avatar
Cougar41
Ok. I'm ****. It's fixed or they don't turn on at all?
Old Jul 16, 2013 | 01:49 PM
cpttuna's Avatar
cpttuna
no they do not work. (on any setting)
Old Jul 18, 2013 | 08:49 PM
cpttuna's Avatar
cpttuna
The wipers worked once today. I turned them off. when I tried them a second time, nothing happened.
Old Jul 22, 2013 | 10:17 PM
cpttuna's Avatar
cpttuna
4 wires run from the wiper motor to a connector in the engine compartment. I eliminated the connector and spliced and soldered the wires together. The wipers still do not work. I rotated the relays. no luck there either.rear wiper does not work either.
