2001 Grand Dodge Caravan need Torque Spec to Transmission oil pan bolts.
Old Sep 4, 2013 | 08:41 PM
riverjamie's Avatar
riverjamie
Default 2001 Grand Dodge Caravan need Torque Spec to Transmission oil pan bolts.
Does someone out there have the torque settings for the Transmission Oil pan bolts? thx
Old Sep 4, 2013 | 09:59 PM
riverjamie's Avatar
riverjamie
Just found it 165inlb.
Old Sep 7, 2013 | 12:34 AM
2therock's Avatar
2therock
Tell us why you ask?
Old Sep 7, 2013 | 11:01 AM
riverjamie's Avatar
riverjamie
Just needed because of fluid change.
Old Sep 7, 2013 | 12:22 PM
2therock's Avatar
2therock
OK, I asked because sometimes folks see a leak and think its the pan and it turns out to be the shift solenoid pack above it drooling down to create the look of it. Including myself. I made sure by gunking it all clean and running a few minutes and flash-lighting the areas and found it.
Old Sep 8, 2013 | 12:51 PM
riverjamie's Avatar
riverjamie
Thanks for the tip, that still could be the case, but hopefully not. There was some dripping but I thought it was coming from the bottom area of the pan. But I also saw some up near the top of the pan below the solenoid area. So you might be right?
If it is, is there a gasket behind the solenoid pack?
How is it sealed?
Can the solenoid pack be removed without draining the transmission?
Do you know what the torque settings are for the mounting bolts for the solenoid pack?
Thanks again
Last edited by riverjamie; Sep 8, 2013 at 12:57 PM. Reason: Needed to add some thoughts
Old Sep 8, 2013 | 01:22 PM
2therock's Avatar
2therock
I had a drip and just knew it was the pan gasket. Years of experience had me gunk it while it was still kind of warm. I hit it every everywhere I could and sprayed it off, then gave it a visual with a flashlight and a mirror on a stick before running to check for spots I missed.
Once cleaned I ran it for about a minute and flash-lighted it again. And there it was coming from the Solenoid pack's mounting surface.
You don't want to run it too long and it get too hot to crawl and it may leak enough to weep around and fool you. A little at a time.
There is no just changing the gasket. They crack. And if you are in there already, and as cheap as it is along with how common it is for them to do this, swap it.
Here is a link to the thread I posted. It was crammped and I was told if I had removed the battery and tray it was much better but I got it.
Good Luck
Old Sep 9, 2013 | 01:38 PM
riverjamie's Avatar
riverjamie
Thanks for the info. Did you have to drain the ATF first?
Old Sep 9, 2013 | 10:23 PM
cv2003's Avatar
cv2003
Just about everything you could want to know about this DIY.
http://forum.chryslerminivan.net/sho...ack-w-pictures?
Old Sep 10, 2013 | 12:16 AM
2therock's Avatar
2therock
No, very little fluid was lost.
