[2nd Gen : 91-95]: Lower transmission coolant hose 95 Gr Caravan
Old Dec 16, 2013 | 12:36 PM
quattj's Avatar
quattj
Default Lower transmission coolant hose 95 Gr Caravan
Any suggestions on where to find a molded transmission coolant hose? All of the ones I have found say "without A/C". I have A/C.
I did locate one on the AutoZone website under "Duralast/Transmission Cooler Line Assembly" Part Number: A61092 but it is special order, and when I add it to my cart it says it's not available.
Curious to know if this is going to be another "have to get it from the dealer" part, and if so what the part number is.
Thanks.
Old Dec 16, 2013 | 11:16 PM
master tech's Avatar
master tech
Site Moderator & Tech
Then you must have a 3.0L engine? And you need the lower hose than goes from the radiator to the crossover tube above the transmission?
Old Dec 17, 2013 | 03:25 PM
quattj's Avatar
quattj
Sorry, forgot a few details:
1995 Grand Caravan SE, 3.3L automatic FWD with A/C
The hose is located down low in the engine compartment. It's maybe a foot long? Looks like the picture on the AutoZone site, except mine doesn't have the heat shield part around it.
I'll upload a picture in a few.
Old Dec 17, 2013 | 05:16 PM
master tech
Okay, you need the transmission cooler lines. The mopar part number is 4682649 and it still avalible.
Old Dec 17, 2013 | 11:24 PM
quattj's Avatar
quattj
It's this Mr. Leaky Hose (top down view, radiator fan at the bottom left). Ill check out that part number. Thanks.
Old Dec 18, 2013 | 10:24 AM
master tech
Thats the part number for those hose's. You will get both of them.
Old Dec 19, 2013 | 01:03 PM
quattj's Avatar
quattj
Hmm. Rockauto shows a Dorman 624344 as the equivalent of this, but the Dorman website only says it fits a 3.8L 1995 Town and Country. Do you know if that is indeed the correct Dorman number, or should I just bite the bullet and spend the extra few bucks for the genuine Mopar part?
How much fluid am I going to lose when I change the lines out? (assuming there's still a decent amount left in there, which there probably isn't) Does the transmission hold most of the fluid, or is more of it in the oil cooler?
Old Dec 20, 2013 | 10:18 PM
master tech
Sorry I should have written, that part number is for both the 3.3 and 3.8 with A/C.
Old Dec 21, 2013 | 12:23 PM
quattj's Avatar
quattj
Okay, cool. I will order one then. Thanks.
