[4th Gen : 01-07]: Hard Start
Old Mar 30, 2014 | 10:34 AM
niereschersprints's Avatar
niereschersprints
Default Hard Start
I have a 2002 Dodge Grand Caravan 6cyl. Flex Fuel. It will not start unless the accelerator is all the way to the floor and when it starts its rough and smells rich. I have replaced the TPS,Idol air control valve and the egr valve. Any suggestions would be greatly appreciated. also when I am cranking it the odometer reads done.
Old Mar 30, 2014 | 04:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
Open the wire harness on the rear cylinder head. That is the injection harness and wires going t the TPS and temp sensor. If the wires are shorted together, replace the harness and the PCM.
