[3rd Gen : 96-00]: 1996 Dodge Grand Caravan
Old May 18, 2014 | 11:44 AM
diesel.2784's Avatar
diesel.2784
Default 1996 Dodge Grand Caravan
Hello, so I have had this problem for a while now and I think I have it narrowed down but I wanted to see if I could get other opinions before I went through with anything.
My van has an electrical problem. Every so often the information cluster will shut off for a period of time, the alarm set light will come on, sometimes the door locks will go crazy, and then sometimes it just won't start. I was sitting at the gas pump the other day and it decided it didn't want to stay running. So I had to push it into the gravel next to the gas station and when I came back the next day it still wouldn't start. Finally after 2 days it started. It only does it when it's warm out. Well it didn't do it all Winter so I assume the heat has something to do with it. I am pretty sure it's the body control module but I'm not a big mechanic so maybe someone else can help. Thanks
Old May 20, 2014 | 12:21 AM
master tech's Avatar
master tech
Site Moderator & Tech
Before you think about the body control module. I would like you to try this first. Remove the cluster and drive the van. See if you still have a problems with a no start. I'm thinking that your cluster is taking the buss circuit down.
Old May 20, 2014 | 01:43 PM
diesel.2784
Hey, thanks for the reply. I am lucky in that there is junkyard close to me where I can get a body control module for 20 bucks. I almost wish my van would quit all together because it would be easier then. It doesn't do this enough to disconnect the cluster.
Old May 20, 2014 | 03:05 PM
Cougar41's Avatar
Cougar41
If it's not the BCM check the connector solder connections on the instrument cluster circuit board for cracks. A well known problem on 3rd generation 96-00 vans. It can effect the data bus and cause engine shut downs, no-starts and erratic instruments. It's a free easy fix.
