[5th Gen : 08+]: Transmission whine 2014 Caravan RT
Old Sep 27, 2014 | 09:07 AM
rtcaravan2014's Avatar
rtcaravan2014
Unhappy Transmission whine 2014 Caravan RT
Has anyone experienced a whine from the transmission in the new Caravans? I have a 2014 RT model that exhibits a slight whirring sound when it downshifts between 10 and 15 mph. The van has about 5000 miles on it now. It started making the noise around the 1500 mile mark. I have not had it back to the dealer yet. My previous van, a 2011 Crew with the same drive train did not make this noise. Any ideas about what might be going on?
Old Oct 3, 2014 | 04:34 PM
1wraith's Avatar
1wraith
I have a 2012 with 60K mi. I do not have a whine. I do however have a loud clunk when it down shifts in traffic. Take it to the dealer and post back your results.
Old Oct 6, 2014 | 10:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
Remove the input sensor and inspect for metal on the sensor, If it does the bearings on the underdrive compounder. But that's a guess.
2nd post. Remove the front tires and re-torque the drive axle nuts at 165 foot pounds.
Old Oct 8, 2014 | 08:41 AM
1wraith's Avatar
1wraith
Thanks for the advice. I went to do this as I needed to rotate my tires anyway. I don't have a socket that large. Do you happen to know what size that is?
Old Oct 8, 2014 | 11:25 PM
master tech
The socket is 1 1/4 in size and use 1/2 inch drive.
Old Oct 9, 2014 | 03:46 PM
1wraith's Avatar
1wraith
Thank you. I appreciate the help. I'll pick up the socket and post back with in a couple of weeks.
Old Oct 9, 2014 | 11:11 PM
georgef's Avatar
georgef
A 32mm socket will also work.
George
Old Oct 9, 2014 | 11:19 PM
georgef's Avatar
georgef
...2nd post. Remove the front tires and re-torque the drive axle nuts at 165 foot pounds.
master tech,
I've seen the torque for the axle nut listed as 118ft-lbs in three separate documents, are they all incorrect, or did Chrysler change the torque spec, or are you just suggesting over-torquing the nut to correct the problem?
When I replaced the wheel bearings on my 2009, I torqued the nuts to 118ft-lbs, should I re-torque them to 165ft-lbs?
George
Old Oct 12, 2014 | 09:18 PM
vipergg's Avatar
vipergg
We have a 14 and it has a noticeable whine in more than 1 gear and it is most noticeable between 50 and 60 mph. Been debating whether to have it looked at or live with it and hope eventually it will go away , we have about 7500 miles on it.
Old Oct 13, 2014 | 05:14 PM
rtcaravan2014
Have not had a chance to take it back to the dealer. Whine started about 1500 miles and continues at 5800 miles. It does not whine at highway speed but when slowing down. Sounds a lot like an old fashioned gear whine from a manual transmission. It probably starts about 25 mph. It does not happen on acceleration. I do not think that it is going to go away on its own.
