[3rd Gen : 96-00]: What're you lubing the siding doors with?
Old Oct 3, 2014 | 12:26 AM
issakar's Avatar
issakar
Default What're you lubing the siding doors with?
Jut curious about what is being used to lube the rollers on the slider doors. One webpage I read said something about Krytox lubricant, and that stuff is EXPENSIVE.
Old Oct 3, 2014 | 02:00 PM
issakar's Avatar
issakar
Is no one maintaining their sliding doors?! Blasphemy!
Old Oct 3, 2014 | 03:30 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I lube my sides so I can road test Crossfires !
Be careful spraying lubricant in the track, Don't get it on that chain harness. Keep debris out of the lower recess.
Just white lithium will be fine...something that will stick. Or some of that clear yellow snot used to lube window hardware.
Winzer makes Polylube 250 which is wonderful stuff. It's a spray gel, but you shake it up well before using it.
Old Oct 3, 2014 | 03:47 PM
Cougar41's Avatar
Cougar41
Hmm. Haven't lubed them in 19 years. Working fine.
Old Oct 3, 2014 | 03:53 PM
issakar's Avatar
issakar
I'm jealous of your so-cal van :-p
Here in the salt belt things don't hold up so well
Old Oct 4, 2014 | 09:52 AM
ice445's Avatar
ice445
My van was a salt belt warrior and I never lubed the door tracks either. The factory yellow grease should last forever unless water gets in the track on a regular basis or something. With that said, use white lithium grease. It's meant for these kinds of applications and is cheap.
Old Oct 4, 2014 | 04:14 PM
Cougar41's Avatar
Cougar41
Ya, it does have it's advantages. Just wish we could have a tenth of your rain.
Old Oct 8, 2014 | 11:28 PM
Mikeb-rick's Avatar
Mikeb-rick
I use white lithium grease. Passenger sliding door never gets any use and is hard to open til I put some.
