[5th Gen : 08+]: Replace Rocker Arm Assembly 2010 4 litre
Old Oct 8, 2014 | 10:38 PM
Doneworking's Avatar
Doneworking
Default Replace Rocker Arm Assembly 2010 4 litre
I have a 2010 Grand Caravan SXT 4 Litre with tow package.
Here is my dilemma.
I have had the Rocker arm assembly replaced twice once at 44000km and once at 60000km. Both times the diagnosis was the same. Quote from invoice “Exhaust Lifter CarriageWorn into shaft supports causing lifters not to seat properly on valve stem.” The dealership was great and did the work under warranty.
This is how it happened both times.
When the weather started getting colder in the fall the engine would start tapping only at start up in the mornings. This would continue on through the winter and progressively get worse until it never stopped tapping. Happened exactly the same way both times.
However when they repaired it the second time there was a note on the work order that said “Replace Rocker arm assembly, as per engineering recommendation CASE NR 60004927” Do any of you know what they might have done and if this fix will last. I really like this van and would like to keep it but if this ends up being a $1000.00 regular maintenance item. The thought of this really concerns me.
Sorry to repeat my question but does any one out there know what they have done and will it work as a good permanent solution.
Thank you.
Old Oct 8, 2014 | 11:39 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would try changing the oil first, what weight of oil are you using now?
Old Oct 8, 2014 | 11:49 PM
Doneworking
Iuse the recommended 10W30.
Old Oct 8, 2014 | 11:51 PM
master tech
Try 10/40 and see how that does.
Old Oct 9, 2014 | 07:42 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
hooly crap I have same vehicle but no noise 4300km hope mine don't leadinto that.
Old Oct 9, 2014 | 08:40 AM
Doneworking
I don't think it's an issue that all 4 litres have. But have been payingattention to other 4 litres and I occasionally have heard the same tapping. Itis frustrating. Makes me lose confidents in owning the vehicle. Makes me wantto trade it in. Of coarse that’s what Chryslers wants us to do.
Have someone start it or use your remote start if you have one with youstanding near the front of the vehicle on a cold morning. This is how I firstnoticed the tapping. It progressively got worse.
Old Oct 9, 2014 | 09:15 AM
DodgeCACares's Avatar
DodgeCACares
Here is my dilemma.
Thank you.
Doneworking,
I'm sorry to learn of your issue. The case # provided is an indication that your Dealer has been in contact with Chrysler's technical support group and has used all of the resources available to address your concern.
In regards to the repairs completed, I would recommend speaking with the Service Manager at your Dodge Dealer for further technical details and a breakdown of the work order if necessary.
Old Oct 9, 2014 | 01:23 PM
Doneworking
Originally Posted by DodgeCACares
Doneworking,
Thank you DodgeCACares,
Itried getting more details when the work was done but as always the poor guy was very busy rushing around and really didn't have the time to tell me indetail. I will try calling him and will ask again.
Old Oct 9, 2014 | 03:02 PM
Doneworking
Hello DodgeCACares,
I contacted the service advisor; he told me the engineering recommendationwas to replace the parts. No special instructions. Still feel the same don’t have the confidence that it won't do it again. If you can shed some light on if it will last or do it again I would be thrilled.
Thank you again.
Old Oct 9, 2014 | 04:24 PM
DodgeCACares
Hello DodgeCACares,
Thank you again.
Doneworking,
Your dealer has been utilizing the resources at their disposal in order to address you concern. Based on that review, it was determined that the rocker arm assembly was required.
As you can imagine, predicting anything in the future has its challenges. However, the purpose of the extensive review and dealer communication with our tech group is to ensure accuracy and avoid repeat trips to the dealer.
