2005 Chrysler Town and Country rear brake lights hazards and turn signals not workin
rear brake lights rear turn signals rear hazards all not working. front turn signals front hazards all work fine tail lights work reverse lights work only rear brake lights and Hazards turn signals not working. Fuses are good bulbs are good.
All die at the same time? Upper brake light out? Any related history?
Could be a processor glitch in the FCM or BCM. Disconnect the negative battery cable for 5 minutes to reset.
Rear light assembly connector pinout. Same for left and right:
pin 1 - turn/flasher/brake power from BCM
pin 3 - parking lights power from park lamp relay in IPM
pin 5 - ground
Check for power at pin 1 at connector then at the socket power contact
Each assembly uses a single ground point for all lights. Parking lights good so ground is good. Could still be loosing ground in assembly circuit test from socket ground contact to back of assembly connection.
pin 5 - ground
Any luck on this? My father is having the same issue on his 2005 Chrysler Town and Country.
Thread is 4 years old. Best to start your own thread describing your issue.
