[5th Gen : 08+]: New Fob Keyless entry stopped working
Old Oct 23, 2019 | 04:16 PM
bigzdog's Avatar
bigzdog
Default New Fob Keyless entry stopped working
Bought 08 Caravan 2 years ago which only had 1 fob. Bought 2 replacement fobs online and had local locksmith program so I now have 3. 1 original, 2 aftermarket. All good and working. Day to day we use the aftermarket fob.
Last week my battery goes bad in van so I replace it. Van was without battery for probably an hour while I was working and swapping. New battery in and all working including keyless entry on all fobs
Couple days later keyless entry stops working on both aftermarket fobs. Original fob still works with keyless entry. Almost like it lost the 2 aftermarket fob programming?
All 3 fobs still start the van
Any ideas to get keyless entry working without going back to locksmith/dealer? (never go to dealer unless I absolutely have to as there is always a several week wait)
Old Mar 7, 2020 | 02:10 PM
Leon Friesen's Avatar
Leon Friesen
Did you ever get this key fob issue resolved? I'm having a similar problem on my 2015.
Old Mar 9, 2020 | 09:11 AM
DodgeCares's Avatar
DodgeCares
Hi Leon, We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support.
Rob
DodgeCares
Old Mar 11, 2020 | 01:36 AM
master tech's Avatar
master tech
Site Moderator & Tech
2015 to program the fobs, you need to have a star scan and not a DRB3 or laptop. Also buying aftermarket fobs are a 50/50 chance that they are good.
Old Mar 11, 2020 | 10:29 AM
Leon Friesen
I was suspicious of the aftermarket fobs too, but my one working fob is aftermarket, while the Dodge fob is one of the nonfunctional ones. Weird, huh?
Old Mar 11, 2020 | 12:24 PM
master tech
Who is doing the programing?
Old Mar 11, 2020 | 02:27 PM
Leon Friesen
Two separate local Dodge dealership did the programming for 2 aftermarket fobs (purchased a few years apart.
Old Mar 15, 2020 | 12:26 AM
master tech
What type of scanner are they using to program the remotes?
