[5th Gen : 08+]: Replaced transmission, cranks, tries to start, no joy
I got my transmission rebuilt last year and the shop owner told me that some people buy used transmission at the junk yard and installed them which can cause a lot of issues. The replacement transmission TCM has to reflash and paired to the vehicle ECM if it doesn't recognize it won't be able communicate with the TCM which could cause a no pulsating signal to the injectors from ECM. He said Dodge/Chrysler vehicle are the worst ones for having these issues with communication failures between the modules. You need someone with an advance scan tool that knows exactly what they're doing to check this out for you.
What is your experience? When you turn the key does it crank or just click or just silence? If it cranks does it catch (gas ignites and the engine is turn by explosion if even for a second)? Does it run and then die, and if so how many seconds or minutes before it dies?
Thanks everybody for all of your input. I finally got it running last night!!!! Below is a condensed version of what I did....
After replacing the transmission, both transmission mounts, right shaft extension (bearing shot), exhaust flex pipe and oil & filter change on engine and transmission, the van would not start. Kicked but no start.
Checked fuel pump & pressure, OK
Checked TIPM, OK
Opened wiring harness where it may have been disturbed removing the transmission, OK. Checked connectors at ECM, OK
Drained electronics, powered down, shorted removed battery terminals, no joy
Checked all wiring, sensors
Removed crank position sensor. On bench test it tested intermittent, replaced, no joy
The left bank cam angle sensor threw a code. Bench tested it, intermittent fault, replaced, no joy
Removed intake and spark plugs, compression was low, 85 to 130, most likely due to the cylinders washed down trying to start so many times
Checked all plugs for spark, ok
Added oil to cylinders, increased compression.
Removed fuel rail, jumped fuel pump, no leaky injectors. Activated injectors individually, perfect spray pattern, all identical, no leakage
As I was removing valve covers, I noticed a hose was chaffing on the wires to the right intake cam phaser, exposing the bare wires. Taped up and secured the hose away during re installation
Removed valve covers and found the 2nd intake on the right cam lobe badly worn because of a failed rocker arm. Replaced cam and 6 rockers. while inspecting the other cams, I noticed that the magnetic ring on the end of the cams (used by the crank angle sensors) was covered in fine metal particles. I cleaned all 3 remaining one ones. Could this magnetic buildup throw off the cam angle sensors?? Put it all back together and it started first try and ran like a charm!! Joy, Joy
So I am thinking a combination of factors?
Checked TIPM, OK
