[4th Gen : 01-07]: Washer fluid not working
Old Apr 17, 2021 | 10:49 AM
Eric Knight's Avatar
Eric Knight
Default Washer fluid not working
Neither front or rear washer pumps are working. Removed them and tested them with a 9 volt battery and jumper wires. Both are fine. The wiper switch activates blades on windshield but wont engage washer motors.
Old Jul 11, 2021 | 11:04 AM
Alexander Polozov's Avatar
Alexander Polozov
Check contacts between FCM and IPM
FCM
IPM
Old Jul 12, 2021 | 01:08 AM
master tech's Avatar
master tech
Site Moderator & Tech
Couple of Ideals. Did you remove the connector a check to see if you had power and ground? And are the washer bottle full? If you don't have power and ground I would start looking at fuses and maybe the multi- function switch.
