[2nd Gen : 91-95]: what size of taper bore should I buy dodge 3.3l engine
Old Jun 27, 2023 | 01:13 PM
meesmotors's Avatar
meesmotors
Default what size of taper bore should I buy dodge 3.3l engine
I ned to buy a taper bore piston rings compressor for a 1995 plymouth voyager 3.3l engine. What part should I measure.
Old Jun 27, 2023 | 03:33 PM
Taper bore??? Generally, if the bore isn't straight, it's time to bore it oversize.... In any event, measure the top of the bore.
Old Jun 27, 2023 | 03:47 PM
meesmotors's Avatar
meesmotors
You do know I am referring to the taper bore tool.
Old Jun 27, 2023 | 08:21 PM
I haven't the faintest idea what you are talking about.
Old Jun 28, 2023 | 12:19 PM
meesmotors's Avatar
meesmotors
It is a tool that you can push the pistons directly into the engine without using an adjustable spring compressor.
Old Jun 28, 2023 | 03:38 PM
Ah. Then yeah, measure the top of the bore, get one that is slightly smaller, but, has some provision to prevent IT from going into the bore as well.
Old Sep 24, 2023 | 04:19 PM
madhu's Avatar
madhu
Low miles for that old of a truck. Id buy it.
Kodi
Old Sep 24, 2023 | 05:17 PM
meesmotors's Avatar
meesmotors
It actually is for sale 160k miles but it has issues. https://www.facebook.com/marketplace/item/976112460113060/
