1999 Voyageur Help plz!
Old Apr 11, 2006 | 12:50 AM
BFG's Avatar
BFG
Default 1999 Voyageur Help plz!
Ok...
I have 99 Plymouth Voyageur... here are my problems.
#1 Air Bag light is on and staying on.
#2 Cruise Control does NOT work
#3 Horn does NOT work.
I checked all the fuses and they are fine.
I went into the IPM and looked at the fuses in there too.. they are ALL AOK.
All 3 of these problems happened at once.
Any thoughts?
Thanks in advance guys!
Old Apr 12, 2006 | 12:19 AM
vangonebuy's Avatar
vangonebuy
Default RE: 1999 Voyageur Help plz!
The most likely suspect is the clockspring assembly.
All the symptoms are perfect.
Call the dealer explain the symptoms and act surprised when they diagnose it.
Extremely common and I was told there is a lifetime warranty.
Good Luck.
Old Apr 14, 2006 | 06:19 AM
zum_23's Avatar
zum_23
I am having the same problems with my 97 GC
Old Apr 15, 2006 | 05:55 PM
vangonebuy's Avatar
vangonebuy
If we created a top 10 problems for the Chrysler/Dodge/Plymouth minivans.
1 would be Transmissions.[:@]
2 would be clock spring.
3 spark plug replacement. (yes, it can be done)
4 trouble code deciphering.
5 front stabilizer bushings
6 Front brakes and rotors (buy in bulk)
7 fuel filters
Did I leave anything out???
Old Apr 16, 2006 | 12:23 PM
1994shadowman's Avatar
1994shadowman
yes it can but why DCX decided to place the back of the motor so close to the firewall is beyond me. When we replaced the spark plugs on my mom's 2000 Caravan we had to use an elbow attachment with the ratchet just to snake around to get at them.
I personally think that is a good number on your list. [:@]
Old Mar 29, 2007 | 11:54 PM
rthegremlin2's Avatar
rthegremlin2
Does the clock spring issue affect the cruise control operation. I just had the clock spring done on my wifes 98 GC and it cured the airbag light and the horn works now but the cruise is still inoperative.
Old Apr 1, 2007 | 11:45 PM
vangonebuy's Avatar
vangonebuy
Yes, It does connect to the cruise buttons.
I would call the dealer back and complain if the cruise worked previous to the problem.
You may get some satisfaction.
Old Apr 3, 2007 | 07:14 PM
yttaf's Avatar
yttaf
I just had my clock spring replaced & my cruise control is working now.
Oh & the spark plugs atlest on the 3.0L aren't that hard to change, I couldn't see the 3.3 being that much worse. Do you guys remove the wiper cowl? That gives perfect access to the rear spark plugs.
