Help me get the wife back on the road
Old Aug 24, 2006 | 09:22 PM
easy81on11's Avatar
easy81on11
Default Help me get the wife back on the road
My wife drives a 93 Caravan and it died out of the blue the other day.
I checked for fuel and spark and they are fine but it just cranks and cranks.
Help me please..
Old Aug 25, 2006 | 11:20 AM
ASH's Avatar
ASH
Default RE: Help me get the wife back on the road
First, what motor do you have?
It could be a sensor, such as the camshaft position sensor. Try pulling the codes. You can do this by turning the ignition switch on and off three times in a row and then watching the check engine light flash. The procedure and code identification is outlined in the Haynes manual, although I'm not positive you can do this with your year of vehicle. The codes will help identify if a sensor is not working properly.
You can pick up a Haynes manual at most any parts stores if you don't have one. They are great for helping you fix your vehicle.
Old Aug 28, 2006 | 07:40 PM
easy81on11's Avatar
easy81on11
the Caravan is a 1993 with a 3.0 motor with 90000 miles.
I dont think I can get the codes that way?
Old Aug 28, 2006 | 08:40 PM
floorslayer1's Avatar
floorslayer1
Yes you can get the codes from the check engine light. blink pause blink blink is code 12 for instance.... turn the key off to on 3x and leave on without starting the van to do this....good luck
Old Aug 28, 2006 | 11:14 PM
easy81on11's Avatar
easy81on11
OK thanks that worked great!!!!!
Now can you help me tell what it means?
here goes: on-one blink-two blinks-five blinks-five blinks.
Any ideas?
Old Aug 29, 2006 | 01:34 AM
floorslayer1
LOL.... either you essentailly had no codes (12 is start of codes and 55 is end of codes) or you did a battery disconnect very recently before you did this maneuver.
Old Aug 29, 2006 | 11:43 AM
easy81on11's Avatar
easy81on11
I kinda thought that after looking threw the Chiltons book.
Im gonna try some starter fluid into the intake and see if it tries to fire
but I have a fealing it jumped time.
Do you or any-one know if doing a timing belt is fairly easy enough
for a semi mech. inclined person to do in his back yard?
Thank for any input.
Old Aug 29, 2006 | 03:56 PM
easy81on11's Avatar
easy81on11
Ok
I put starting fluid into the intake and it runs
till that is gone, any ideas?
Old Aug 29, 2006 | 04:53 PM
webbee's Avatar
webbee
If it runs on starter fluid you probably have a fuel supply problem. Check to see if the fuel pump is working or if the fuel filter is plugged. It could also be plugged/not working injectors.
Old Aug 29, 2006 | 05:02 PM
Thansen's Avatar
Thansen
EGT? Empty Gas Tank? I know it may be overlooked, but sometimes my Chrysler doesn't start, even with 1/4 tank of gas. I'd just say, check the filters (like the previous comment stated) and other fuel related parts. If you get it running, try using some FI (fuel injector) cleaner to clear out the junk in the injectors as well. It can only help in the future.
