Caravan Do It Yourself information
Old Oct 9, 2009 | 04:00 PM
  #21
alexfbi77's Avatar
alexfbi77
One in fuel tank, and there is no more filters, unless some one putt there by it self. And right behind battery, there is a gas canister filled with charcoal, that is final very thin filter, that it.
Old Oct 9, 2009 | 04:08 PM
  #22
alexfbi77's Avatar
alexfbi77
Originally Posted by gugge
Please i need help.
My dodge grand caravan won´t start.
The engine turns around but it won´t start.
Anybody who can help me and tell me what can be wrong?
Thanks Gugge
:i con_laugh::ico n_laugh::icon_ laugh:
Who are you M or W?
Old Nov 9, 2009 | 10:40 PM
  #23
paulduster2001's Avatar
paulduster2001
Hi I have a 2002 Grand caravan. The fuel tank colapses when I accelerate. The engine light is on. I switched a solonoid purge valve from a buddies van to test it and the problem went away. I bought a new purge valve and the problem returned. Help!!!
Old Nov 10, 2009 | 01:48 PM
  #24
alexfbi77's Avatar
alexfbi77
Did you check the plug to it, make shure is clean. Before i didn't pay much attention to plugs, but one day i admit plug to be wet, and my van went in LIMP mode. So i took air hose and blow all plugs i was working with. And poroblem gone for good. But even after you did change purge valve, and the CEL come's back either one is bad, purge valve you bought, or wet or dirty plugs, and plug shorting. Or new though bad gas, wich is with water or some small trash. So any way what the OBD Code? on this problem? Did you check with OBD-II reader? if yes what's the code?
Old Nov 11, 2009 | 10:11 AM
  #25
DODGE 2.4's Avatar
DODGE 2.4
Default 2001 engine replacement
hello my fellow dodge fans.does anyone out their know or have the DO IT YOURSELF steps to removal of and installing of a 2.4 engine for my 2001 dodge caravan.i have found a motor and would like to replace it myself.can anyone help me out with some info
Old Nov 12, 2009 | 01:28 PM
  #26
alexfbi77's Avatar
alexfbi77
Whell first you need engine lifter, and a car platform to lift a van. You won't be able to pull engine up throu hood area, engine has go down, and when engine is down on ground, then lift the front of the van so you can swap the engine, working same way up.
Old Dec 31, 2009 | 10:31 PM
  #27
82prospector's Avatar
82prospector
Originally Posted by 94rt10ohio
Click for Caravan DIY.
DIY's are supplied by you, our members! If you would like to add a DIYPM the DIY to 94rt10ohio
Linky no worky STILL
Old Jan 17, 2010 | 04:17 PM
  #28
johnsonsvan's Avatar
johnsonsvan
I have a 2008 Grand Caravan with an RES radio. The UConnect buttons are there but it says not equiped. What parts do I need to connect the radio and be able to use the Uconnect system????
Old Jan 28, 2010 | 09:31 AM
  #29
srt4bad's Avatar
srt4bad
still no link!!!
Old Feb 2, 2010 | 10:18 AM
  #30
DanK5's Avatar
DanK5
Originally Posted by Socialbutterflyinc
I have a dodge grand caravan 2005 with 85k miles that has an antifreeze/coolant leak? Is this common? Anyone encountered this?
Would putting leak stop in help?
There is a recall for this if the leak is from under the body of the van. I just heard about this. The clamps on the underbody coolant lines loosen and allow it the leak. Free repair at dealership but call and tell them where yours is leaking from to make sure it's covered.
