Dodge Challenger Forum for the 2008+ Challenger. This includes the SE, SXT, R/T, Shaker, Scat Pack, SRT and Hellcat models.
Interpreting Battery Voltage
Old Sep 12, 2025 | 12:01 PM
Hellcatter's Avatar
Hellcatter
Default Interpreting Battery Voltage
I recently put a battery tester on the battery (which is at least six years old) and though the tester came back with a status "Good Battery, Recharge" the voltage read 11.8v. Is it time for a new battery? Not sure if this makes a difference but the car alarm has not been armed and I have not driven the car in a week.
Thanks
Old Sep 12, 2025 | 12:15 PM
Not sure how much of a draw there is on the system when the car is just sitting.... but, if it starts when you tell it to, it's all good. Just drive it far enough to charge the battery up.
Old Sep 12, 2025 | 12:31 PM
Hellcatter's Avatar
Hellcatter
Thanks, HeyYou! It might take the second crank to start but it works. I do drive it weekly, at least ~12 miles. That seems to keep it charged.
Old Sep 12, 2025 | 06:55 PM
Try just turning the key to On, wait for the fuel pump to cycle, then crank the engine, see if it starts any better. (assuming you get a choice in the matter..... )
Old Sep 12, 2025 | 07:17 PM
ol' grouch's Avatar
ol' grouch
Thanks
It's a little low and this winter might kill it. Normally, you want about 12.5 volts, more or less, at rest. If it's been sitting for a while that can lower it. With it running, you want to see 13.4 or higher.
Old Sep 12, 2025 | 07:39 PM
Hellcatter's Avatar
Hellcatter
Thanks, I'll give it a try tomorrow, charge it up, see where it lands voltage-wise. But I'm leaning with popping in a new one.
Old Sep 12, 2025 | 10:15 PM
It is getting a tad long in the tooth.... Though, I have had them last longer, but, I was driving them every day too......
Old Sep 12, 2025 | 11:53 PM
Hellcatter's Avatar
Hellcatter
This a garaged 24/7 RT Classic with great weather. Yeah, it's an old battery.
Old Sep 13, 2025 | 06:56 AM
Moparite's Avatar
Moparite
Try a "load" type battery tester, I seen the ones that are the "no load" and don't trust them. See what the voltage drops to under load. It may be wise to just replace it, Don't want to take it somewhere and one day it won't start. Rule of thumb is 5 years for batteries but can last longer under the right conditions.
Old Sep 13, 2025 | 07:32 AM
Hellcatter's Avatar
Hellcatter
Thanks, and agreed, Moparite!
