Sponsored by:
Sponsored by: CARiD
2011 charger speakers
Old Nov 13, 2012 | 08:20 PM
mssexyldayee's Avatar
mssexyldayee
Default please help
I have a 2011 Dodge Charger. My speakers keep making a loud popping noise. can some tell Why it's doing that?
Old Nov 13, 2012 | 08:37 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Popping usually means that the speaker is blown.
Do you still have the factory system in or have you had it replaced? You can fade out the speaker with the controls to verify it. If it is one of the rears, fade it to the front. No popping from those, the you can rule out the stereo and look to getting new speakers.
Old Nov 13, 2012 | 09:00 PM
mssexyldayee
Yea everything still factory and all the speakers make the same popping sound. Only when the volume is below 22
Old Nov 13, 2012 | 09:48 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
If all the speakers are doing it, then we can rule out the speakers. Below 22 volume would tell me you either have a bad ground or a bad amp. Most likely the amp though.
If you are losing sound at all, you can look at a bad ground. If you are not losing sound and have the constant popping, then it will be more towards the amp. Ground can be repaired cheaply but if it is the amp, it will require to be replaced.
Did you buy it new? Do you still have the warranty? If so, take it to the dealer as both would be covered under the bumper to bumper warranty. If it is out of warranty, it will be cheaper to take it to a car audio place as they are much cheaper.
Old Nov 13, 2012 | 11:41 PM
steak59's Avatar
steak59
Check the built date of your vehicle, see if TSB below applies. it is on the sticker by the driver's door. And do you have base radio or 8.4" touch screen?
TSB NUMBER:
08-044-11
GROUP:
Electrical
DATE: August 02, 2011
SUBJECT:
Clock Loses Time, Audio Makes Popping Noise
OVERVIEW:
This Bulletin involves removing and replacing the Telematics Gateway (TGW) / Radio.
MODELS:
2011 (JC) Journey
2011 (LD) Charger
2011 (LX) 300
NOTE: This bulletin applies to vehicles built before May 13, 2011 (MDH 0513XX)
equipped with a UCONNECT TOUCH 4.3S CD/MP3/SAT (sales code REB) or a
UCONNECT TOUCH 4.3 CD/MP3 (sales code RHA).
SYMPTOM/CONDITION:
The radio's clock loses time and/or the audio system exhibits a popping sound.
DIAGNOSIS:
If the vehicles VIN is listed in VIP or your RRT VIN list, perform the repair.
NOTE: Only perform the repair if the VIN is listed in VIP or your RRT VIN list
Old Nov 14, 2012 | 06:20 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
It is always nice to have Dodge techs here who can shed light on active TB's.
By reading it though, it looks like I am right on the amp then. LOL!!
Old Nov 14, 2012 | 09:32 AM
DodgeCares's Avatar
DodgeCares
Ms,
If you PM me your vin I can tell you if the TSB listed applies to your vehicle.
Old Nov 14, 2012 | 09:43 AM
mssexyldayee
I Can't Find The TSB Number By The Driver Door.
Old Nov 14, 2012 | 09:44 AM
mssexyldayee
And Thank Y'all:-)
Old Nov 14, 2012 | 10:28 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Your VIN is needed. You can get it off your registration. The TSB is bulletin mentioned above . He will run your VIN to to see if your car needs it.
