Sponsored by:
Sponsored by: CARiD
P0016 & P000B codes.
Old Nov 23, 2018 | 06:59 PM
djellis87's Avatar
djellis87
Default P0016 & P000B codes.
New member here so first hello everyone!! I recently had a collapsed lifter in 2011 dodge charger police 5.7 that ate into the intake lobe of my camshaft. I replaced everything exactly to manufacturers specs and since i have had the p0016 & p000b codes as well as p0300 and p0301, although i feel that they are related to the first two choices. I took to my mechanic almost 2 weeks ago and the only thing they've done is move my car from where i parked to the side and I'm getting to where i need my car back. Any advice on what to do anyone?
Old Nov 23, 2018 | 09:52 PM
How many cam sensors does your car have? I would think just one.... but, the second code refers to 'bank 1'..... Puzzling.
The first code talks about crank/cam relationship, so, basically, the computer thinks the cam and crank are not synced properly...... Given that you probably have the VVT system as well, is there some specific procedure you need to go thru to install the timing chain? Or initialize the sensor??
Old Nov 26, 2018 | 03:28 PM
djellis87's Avatar
djellis87
Sorry for the late reply been really busy. The car only has one cam sensor located near the water pump on the top of the block, easy to get too. As far as the timing chain installation, it was straight forward and i didn't see anything in the manual about sensor initialization. I leterally just came in the house from replacing the VCT solenoid, hoping thats what it was.
Old Nov 26, 2018 | 04:52 PM
Did it help?
Old Nov 26, 2018 | 06:52 PM
djellis87's Avatar
djellis87
Did it help?
Not at all... :'(
Old Nov 27, 2018 | 09:52 AM
How is your oil pressure? What weight oil did you put in after the work was done? The P000B code talks about oil pressure issues possibly setting the code..... or, a 'slow reacting' cam position sensor. Did you get your sensor from the parts store? Or is it a genuine mopar unit?
Old Nov 27, 2018 | 11:11 AM
djellis87's Avatar
djellis87
Mobil1 5W20 full synthetic
In the car now and the oil pressure is at 51psi.
it's wasn't a sensor i replaced, it was the oil control valve solenoid as d its not a mopar unit.
Old Nov 27, 2018 | 07:00 PM
Oh, in that case, I would take a close look at the sensor, and wiring to it.......
Old Dec 9, 2018 | 12:02 PM
djellis87's Avatar
djellis87
sorry for the extra late reply, i did have bare wire showing on the harness, but i haven't had the time to do anything about it.
Old Dec 9, 2018 | 06:02 PM
Keep us updated.
