Sponsored by:
Sponsored by: CARiD
2009 Charger Starting Issues
Old Feb 24, 2020 | 04:44 PM
C VR's Avatar
C VR
Default 2009 Charger Starting Issues
Got a rebuilt engine installed on my 2009 Charger last year. About a month ago the car would not start. Just a click, all lights and such still worked. I tried to jump with another car to no success. AAA came out and jumped it with a battery pack. Had advanced auto do a check on the battery, starter, alternator and everything checked out ok. A couple of weeks ago it would not start again, same issue, just a click but all dash lights and such still worked. Jumping with another car did nothing. However while waiting for assistance about 15 minutes later I tried to start it and it started up. Seems like the car sporadically won't start and also sporadically will start. Battery cable connections at terminals are tight. Any ideas on this issue?
Old Mar 1, 2020 | 03:31 AM
Marian5,7's Avatar
Marian5,7
Probably damaged starter (brushes hang), check the starter fuse maybe something is not connecting.
Old Mar 1, 2020 | 11:47 AM
primem's Avatar
primem
+1 for worn brushes...if it is worn brushes...when the problem occurs, if you tap the starter the brushes will seat and the car may start...replace brushes or starter.
any starting or charging system problem...rule out the battery first.
Old Mar 11, 2020 | 01:48 AM
master tech's Avatar
master tech
Site Moderator & Tech
Inspect you TIPM module and check all the connection. You could have a wire that back out for the starter system.
