Dodge ChargerThe Dodge Charger. The car that made its competitors shiver in the 60's is reborn in 2006 into a sleek sedan that can still send the competition home wimpering, the Dodge Charger.
Maybe some one now if ther was a problem with cilinder head gaskets on 3.6 engines on later models. I read that was some problem but on early model 2012-2014
Generally the oil cooler is the culprit when oil is mixing with coolant. When you have 60psi oil and 15 psi coolant the oil can push into the cooling system. These coolers are also known for external oil and coolant leaks on these engines. 200k miles on the wife's jeep and this will be the 3rd one . Hope this helps
