Sponsored by:
Sponsored by: CARiD
Engine Swap Questions
Old Oct 6, 2022 | 05:53 PM
Sedlaflare's Avatar
Sedlaflare
Default Engine Swap Questions
New here, real simple question which i cant seem to find in the forums or online, will a 2019 5.7 charger engine bolt right in like a 2011-14 5.7 will. Friend of mine is selling me his for cheap.
Old Oct 6, 2022 | 06:41 PM
What do you want to bolt it into?
Old Oct 6, 2022 | 06:46 PM
Sedlaflare's Avatar
Sedlaflare
I have a 2011 Rt charger, do the newer years work for the older.
Old Oct 6, 2022 | 09:25 PM
From what I can find, should be the same motor......
Old Oct 7, 2022 | 10:00 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
No. 09-12 and 13+ VVT engines have different crank tone wheels.
Old Oct 7, 2022 | 10:58 AM
Ah, that bit of info was left out of the article I read. Thanks for the correction.
Old Oct 7, 2022 | 02:21 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
The tooth count is the same but the tooth size itself is different. Rumor has it (but unconfirmed) that you can use the later sensor in the earlier car and change something with HP tuners to make it work correctly.
