2018 Charger 5.7 Pursuit AWD Shudder
I've got what seems like a shudder in the trans under light acceleration in most all gears, it's a 5 speed. Highway speeds and around town. The vibration is sometimes fine and sometimes coarse. Anyone experience this kind of thing? I replaced the left cv axle and intermediate shaft/awd actuator. Changed trans fluid with Mopar ATF+4 twice, transfer case fluid with the right Mopar fluid, rear axle oil, still doing it. Any ideas? I had the local trans shop guy drive it and he couldn't say what it was. Thanks.
I tugged and twisted both and the rear was solid, front just had very slight play in the splined shafts. The trans shop guy said the front joint of the rear shaft is a fluid joint but it was tight. So...
Not having to slide around on your back makes inspections much more pleasant.
and you can see stuff better as well.
A dry joint will 'feel' fine, but, under load, when it gets hot, may cause of vibration..... That's a hard one to diagnose though, without disassembling everything......
and you can see stuff better as well.A dry joint will 'feel' fine, but, under load, when it gets hot, may cause of vibration..... That's a hard one to diagnose though, without disassembling everything......
If I break into double digits, I feel I am doin' good. Fortunately, I don't drive a lot. So, not too much of an issue.
Trending Topics
Well the shop said it's the trans with a torque converter shudder, kinda what I was thinking too. Have 3 options Jasper, Mopar, forget the 3rd. Mopar actually close to the cheapest at $6900 yikes. Ever heard of a Diablo tuner fixing a trans problem? Saw a guy on u tube where that happened.
