Sponsored by:
Sponsored by: CARiD
2014 charger
Old Feb 9, 2026 | 10:56 AM
jimkat's Avatar
jimkat
Default 2014 charger
my 14 charger rt wouldn't accelerate at 65 p
mph on highway.It felt like gas pedal would not depress for 2-4 seconds then back to normal
Old Feb 9, 2026 | 12:23 PM
Does your gas pedal connect directly to the throttle body, or is yours throttle by wire?
Old Feb 9, 2026 | 07:32 PM
jimkat's Avatar
jimkat
I dont know, but im thinking the issue is a sensor in the gas pedal
Old Feb 10, 2026 | 07:06 AM
Has it always done this? Just started? Any modifications? Maintenance history? Is the check engine light on? Have you scanned for codes? The more information you can provide, the more help you would get.
Old Feb 10, 2026 | 11:36 AM
jimkat's Avatar
jimkat
tx...no codes at all and 100 % maintained.It has only happened 2x, 6 months apart.I think it needs a new gas pedal, maybe a sensor issue
Old Feb 10, 2026 | 02:14 PM
SHO Rod's Avatar
SHO Rod
There's usually quite a bit of redundancy built into the electronic throttle pedals, and quite a bit of monitoring for diagnostic and failsafe purposes. If you do not have a warning indication in the instrument cluster or pending or stored diagnostic codes pointing to the throttle pedal, I would not personally spend money replacing that yet. Have you checked yet to see if there is a mechanical steel cable controlling your throttle plate or if it has a motor and wires with NO mechanical connection?
Are you interested in diagnosing this issue yourself, or just trying to educate yourself on what a shop might find to be the issue? If you're wanting to diagnose this yourself, do you have a multimeter and are you familiar enough with using it combined with the operation/function of a Throttle Position Sensor (TPS)? Have you opened the throttle plate (only if mechanical) to see if there's a build-up of carbon on the back side?
-Rod
Old Feb 10, 2026 | 04:07 PM
jimkat's Avatar
jimkat
tx I will have my mechanic look into this
