Sponsored by:
Sponsored by: CARiD
ESP BAS
Old Sep 1, 2006 | 07:53 PM
juvezak's Avatar
juvezak
Default ESP BAS
Hi there,
When I started my car this morning the ESP BAS yellow light was on, Am sure i havent abused the brakes or turned the ESP off......I tried to calibrate the steering wheel sencors by turning the steering full left and then full right and center, but the light wouldnt turn off..
I just wanna know whats the problem causing the ESP BAS yellow light to come on, Because am sure the dealer wont fix anything, they just replace parts and make u pay hundreds of dollars for labour while it might be fixed for a couple of bucks. Thanks guys
I have an Sxt by the way...
Old Sep 1, 2006 | 09:12 PM
mnboy's Avatar
mnboy
Default RE: ESP BAS
It may not hurt to take it to a reliable dealer and have them check it... you might pay a few bucks, but it's under warranty, and may save you hundreds down the road. Unless you know what you are doing (and listen to someone who THINKS they know), you could even mess it up even more.
MN
Old Sep 1, 2006 | 09:53 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: ESP BAS
Go w/mnboy's suggestion and take it to the dealer. It may be a steering wheel position sensor or something else dealing w/the CAN Bus.
Good luck!
Old Sep 2, 2006 | 04:48 AM
juvezak's Avatar
juvezak
Default RE: ESP BAS
Thanks guys, I already booked an appointment on wednesday morning.. I'll let you know what happens...
Old Sep 5, 2006 | 01:58 AM
06ChargerSXT's Avatar
06ChargerSXT
Default RE: ESP BAS
I had the same thing happen but the Engine light was on then it
begain to flash they all went off . Also see the Doc WED.
Old Sep 6, 2006 | 01:08 PM
06ChargerSXT
Default RE: ESP BAS
The DOC found it to be scm module gone bad.
Old Sep 6, 2006 | 04:07 PM
juvezak's Avatar
juvezak
Default RE: ESP BAS
I took my car to the dealer this morning...Am waiting for the service tech. to call me when he finishes checking it.. I will update later today "Hopefully"
Old Sep 6, 2006 | 09:05 PM
juvezak's Avatar
juvezak
Default RE: ESP BAS
I just got back from the dealer, the DYNAMIC SENSOR CIRCUIT is defected and they ordered a new module "which is under warrantee"
Old Sep 7, 2006 | 08:46 PM
mnboy's Avatar
mnboy
Default RE: ESP BAS
Glad you got it figured out.
And especially when it's under warranty.
MN
