Sponsored by:
Sponsored by: CARiD
Your header install
Old Mar 10, 2007 | 02:59 PM
  #51
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Your header install
Yes, it can be a trying experience but you made it. What a deal! Now let us know what you think of the performance.
Old Mar 10, 2007 | 03:12 PM
  #52
baldyloxs's Avatar
baldyloxs
Not real sure yet I need to get that exhaust leak fixed.(cant stand to hear it )It sounds sluggish,but has alot more snap when you mash the gas.Ill get out the SC Data logger and do some testing with it .srry no pics I left my camera in my freinds car
Old Mar 10, 2007 | 10:21 PM
  #53
baldyloxs's Avatar
baldyloxs
threw 5 codes P2098,P0420,C121a,C2114,V0125
Old Mar 11, 2007 | 01:23 PM
  #54
74scamp's Avatar
74scamp
Marty, you didn't mention those codes earlier, did they come up sometime after you initially drove it? Had a chance to see what they are yet?
dave
Old Mar 11, 2007 | 02:03 PM
  #55
MangoInTX's Avatar
MangoInTX
Charger Moderator
C121A, C2114 and U0125 are probably caused from the battery disconnect. Step through the ESP/SAS reset procedure:
After prolonged battery disconnect the Steering Angle Sensor (SAS) needs to be calibrated. The SAS requires calibration anytime the battery or an ABS (ESP) component has been disconnected for any length of time. Steps to calibrate:
-Start the engine.
-Center the steering wheel.
-Turn the steering wheel all the way to the left until the internal stop in the steering gear is met, then turn the wheel all the way to the right until the opposite internal stop in the steering gear is met.
-Stop the engine.
P2098 and P0420 are exhaust related. P2098 may be due to the leak. the P0420 is the common one seen with headers.
Code Details...
P2098 - Post Catalyst Fuel Trim System Low Limit. Set by a lean condition.
P0420 - Catalyst System Efficiency Below Threshold (Bank 1). Drivers side #2 O2 sensor
C121A- Steering Angle Sendor Not Initialized. Caused from battery disconnect, turn steering wheel lock to lock to initialize.
C2114- Dynamics Sensor Supply Voltage Low. ESP cut-off switch.
U0125 - Lost Communication w/Dynamis Sendor. ESP cut-off switch.
Old Mar 11, 2007 | 11:03 PM
  #56
baldyloxs's Avatar
baldyloxs
Ok thanks Mango,but where do I find the procedure for the ESP recal.? Do yo uthink if I put the high flows on the P2098 will go away? I still have a leak. I can hear it when the car is under a load,bt not idleing,or revving any Ideas?
Old Mar 11, 2007 | 11:12 PM
  #57
MangoInTX's Avatar
MangoInTX
Charger Moderator
Sorry my bad, didn't mean to imply there's a ESP recal. The ESP evidently takes SAS informationinto consideration when it's doing it's thing. Just step through the SAS reset.
P2098 is probably due to the exhaust leak.
Old Mar 11, 2007 | 11:25 PM
  #58
baldyloxs's Avatar
baldyloxs
Ok well .I think Ill have it fixed so I have no leaks this week.I need to cut a slit in the pipe so when I tighten it up it doesnt shroom/buckle.That tuner is great for those codes,not sure if anyone else has used it but it will tell you what it is and clear them as well.Mamma says car is alot louder on the outside than what it was,n sounds lots meaner. lol
Old Mar 11, 2007 | 11:31 PM
  #59
74scamp's Avatar
74scamp
Sounds good, huh? Cool!! [sm=icon_cheers.gif]
dave
Old Mar 11, 2007 | 11:43 PM
  #60
baldyloxs's Avatar
baldyloxs
UHHH YEAH REAL GOOD !!! lol the girls were in it yesterday the said mom why can I hear the motor so well?
