Sponsored by:
Sponsored by: CARiD
sc results
Old Dec 22, 2006 | 03:22 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: sc results
Yep, just change the setting, no need to go back to stock first. Play with the settings and you'll settle into the ones you like.
Old Dec 22, 2006 | 07:31 PM
RT 2 NV's Avatar
RT 2 NV
Mangointx can you keep the sc installed and still use the programmer to change settings? or is it one or the other. just the chip or just the programmer at one time?
Old Dec 22, 2006 | 07:53 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
The question was a little fuzzy. Here goes...
Several have ran the Jet Chip and used SuperChips at the same time. They started stock so if you had a SC tune currently on the car return the car to stock first. Install the Jet Chip then program again with the SC.
To tune with the SC you plug it in and program the car and then unplug it. If you want to change the program you plug it in again and make changesthen program the car and then unplug the SC.
Now to confuse things, you can leave the SC hooked upand usedata logging feature to time your car (there are several options for logging data by time or distance).
Old Dec 23, 2006 | 08:29 PM
RT 2 NV's Avatar
RT 2 NV
sorry about that. hope this helps. i have the stage two chip and want to get the programmer to change the settings in the car. that is possiable with have the chip in the car? thanks.
Old Dec 24, 2006 | 09:50 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
A couple have done this including the section moderator, 74scamp, without adverse affects.
Here are a couple threads to look at on the subject. Do a search for "jet chip" and you'll find more.
https://dodgeforum.com/m_548395/tm.htm
https://dodgeforum.com/m_534267/tm.htm
Old Dec 27, 2006 | 08:23 PM
74scamp's Avatar
74scamp
I tried it with not ill affects as Mango stated. However, I have since taken my Jet Chip out. I deduced that it really didn't do any thing extra and why risk a potential problem. I'm just as happy with the tuner sans jet chip.
dave
