Aussie Dodge AT4 info and specs
Old Sep 5, 2019 | 01:48 AM
  #51
darrylvanrooy's Avatar
darrylvanrooy
Morning All. Newbie to the group, but this is my heartache for the next few years.
Found it on FB Marketplace. Bought it off a farmer in Hay NSW that was clearing out his shed after owning 5 or 6 and building a couple of good ones out of all the parts he had.
Ute back and cab aren't bolted to the chassis
Old Aug 23, 2022 | 09:48 PM
  #52
halihome's Avatar
halihome
Hi Mousey,
Did you finish making the 1/43 Dodge kits ????
Steve
Old Dec 15, 2023 | 02:26 AM
  #53
saltybumpkin's Avatar
saltybumpkin
Default Dfr
Sorry I don't know how to delete posts yet.. and I had to write something
Old Dec 15, 2023 | 02:36 AM
  #54
halihome's Avatar
halihome
Default Brake Parts
Hi,
You can get brand new master cylinders from https://www.gumtree.com.au/s-ad/temo...nal/1263151255
They also stock wheel cylinder and master cylinder rebuild kits plus a comprehensive manual on a flash stick
The rest you can scout around on ebay
Old Dec 15, 2023 | 02:58 AM
  #55
saltybumpkin
Default 575
Originally Posted by Hillside Park
Hi Andrew,
The only wire/s coming out of the bottom of the steering column will be for the horn. You should find three wires (red, yellow & green) coming out of the top of the steering column just in under the dash and behind the steering column support. These three wires connect to a six post terminal fitting. I've checked the wiring diagram in the manual and visually checked my 1970 AT4. Can you confirm this first part on your AT4 and let me know; then I'll launch into the next step. Alternatively, call 0417820133......regards, David
Hi David
I have stumbled into this thread because you said you have a 1970 at4 575. I have been looking wide and far for info on that exact model because we are about to fly down and drive one 16hrs back home. But what I am really interested in is it's GVM.
The vehicle has written on the side:
Tare - 3850
GCM - 11340, and this is in kg
But no GVM information, what I have found on the internet is differing weights and not quite the same year. I'm wondering what you know about this and if you could give clear information on what it's GVM is.
I'm not sure how this forum works or how old this thread is. I just joined specifically to ask you this question about GVM, hopefully your still on here to see it.
Cheers,
Shelly
Old Jul 6, 2024 | 09:10 PM
  #56
Richo Richard's Avatar
Richo Richard
Default Dodge truck
Hi all New to the group
I have just bought my first Dodge, an early 50's truck, well I am pretty sure it is.
I am trying to find out more info on it via the numbers but can not come up with anything.
I see the prefix AT stands for Australian Truck
What does the AL stand for?
It has a flat head 6 cyl Manual in it.
Dual rear wheels
6 stud on a 7.25" PCD
first tag has,
BERG - AL4317
Second tag
5732 - 845
And the Chrysler Australia Limited tag has
Model Serial No 2 - 33C 251
It also says it is a 8000 LBS
Any help would be gratefully appreciated
Thanks in advance Richard
