Fuel Pump Conversion 1988 to 1991
Old Nov 18, 2024 | 10:01 PM
ThumperJumper1000's Avatar
ThumperJumper1000
Default Fuel Pump Conversion 1988 to 1991
I have a 1988 dodge W150 with a 318, 5.2 liter engine. The fuel pump went out on it but no one makes that unit anymore so I was wondering if it’s possible to convert to a ‘91 in tank fuel pump, and if so how to best go about it. Thanks!
Old Nov 19, 2024 | 10:10 AM
Is
this this
it?
Old Nov 19, 2024 | 10:13 AM
ThumperJumper1000
Is this it?
This is the new pump I’m looking at: https://www.carparts.com/details/Dod...E&gclsrc=aw.ds
Old Nov 19, 2024 | 11:06 AM
The one I linked was for the 88. Should be a direct replacement.... No idea what the conversion would require.
Old Nov 19, 2024 | 06:08 PM
Moparite's Avatar
Moparite
Nothing shows up in the link. Ra has the pump itself but not the housing. If you can get your original out and the new one in you can just reuse the housing.
Old Nov 19, 2024 | 07:58 PM
Try this link..... Advance shows no stock, but, if you search by the part number, that's how I found it on amazon. No clue why amazon is denying knowledge of it now.......
Old Nov 20, 2024 | 08:17 PM
Moparite's Avatar
Moparite
That link doesn't work either,Took the address from it and got this(see if this works) Ra has them also but not the whole assembly. No luck with this link either. Advance is closing stores and don't want people to shop there.
Old Nov 20, 2024 | 08:47 PM
Both links work for me????
Old Nov 21, 2024 | 09:43 PM
Kelikaku's Avatar
Kelikaku
That link doesn't work either ... Advance ... don't want people to shop there.
NAPA has the aftermarket pump and lower price with free shipping. They're really reliable:
https://www.napaonline.com/en/p/DFPFE0079
However a search on Amazon comes up with OEM replacements, several, most of which are both less expensive and also include the sending unit:
Amazon Amazon
Good luck.
Last edited by Kelikaku; Nov 21, 2024 at 09:59 PM. Reason: Fixed the link to fuel pump found on Amazon.com
