Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Mopar EVS alarm system
Old Mar 4, 2007 | 09:17 PM
coder33404's Avatar
coder33404
Default Mopar EVS alarm system
I have a 2006 Dakota R/T with a dealer installed EVS alarm and the darn thing sounds off after I unlock the truck with the remote about every 10th time I arm it. Works most of the time but 1 in 10 it goes off for no apparent reason. This is the EVS 1 unit that uses the regular keyless entry key that came with my truck. I only bought the truck 2 weeks ago and they put the alarm in a week later. Anybody else having problems like this?
Old Mar 7, 2007 | 04:23 PM
batman13's Avatar
batman13
Default RE: Mopar EVS alarm system
how do you lock it?
my sunfire flips if you don't lock/unlock the same way
you can't lock it from the door and unlock it with the remote or vice/versa without attracting a lot of attention
Old Mar 7, 2007 | 09:58 PM
coder33404's Avatar
coder33404
ORIGINAL: batman13
how do you lock it?
Good point, I lock & unlock in different ways at different times. As it is I dont have a clue as to what is wronge with it because it is a sporadic problem. I will try this and see if that is the thing setting it off "every once in a while".
Old Mar 8, 2007 | 08:47 AM
coder33404's Avatar
coder33404
ORIGINAL: ericemery
did you get it into the dealer yet?
No the dealer is not that close and it is such a pain to do that I wanted to have as much information as possible to give them when I do. I just know how this is going to go "back and forth to the dealership". I don't think they really know what they are doing there so after the first attempt I will probably tell them to yank the whole damned thing out and I will go after market.
Check this out, yesterday it went off while disarmed when I shut the small back door. The front door was still opened because I was loading groceries in it. It had been disarmed for several minutes but it seems like it was the motion sensor that set it off that time as I sort of slammed the back door to close it because it didn't close the first time I tried.
Good news is I got the Lojack and Lojack First Alert installed finally
Old Mar 11, 2007 | 03:00 AM
coder33404's Avatar
coder33404
I don't want another fob! Dealer got it resolved, works like a charm now and they threw in a tank of gas for my troubles.
Old Mar 15, 2007 | 08:58 AM
coder33404's Avatar
coder33404
Dont know what they did but I think it was replace the main unit of the alarm. I didnt have time to talk when I picked it up.
