1986 2.2L Daytona (non-turbo) fuel pump? coil? module?
After sitting idle outdoors for nearly 4 years, my 1986 2.2L (non-turbo) Daytona's coil measures only 2.9 volts with the ignition switch on. Is this due to a bad ignition coil? The engine runs briefly if I pour fuel into the intake and start it. 4 years ago it would start and run just fine. The fuel pump is probably bad because it does not run when applying 12v directly to its contacts on the tank. Could the low voltage at the coil be due to a bad power module, or logic module? Help, anyone?
But thanks anyway for telling me what I already knew.
my 86 Daytona did the same thing....the fuel injectors were plugged with old gas...it would only run if you put fuel down the throttle body.
pull the fuel rail off the back of the motor, replace the injectors and put new rubber fuel hoses on the rail while it is off.
If the engine runs when you pour gas down the intake, that would tend to imply the coil is indeed doing it's job, and your problem is fuel related. If the pump isn't running, then the engine isn't going to either. In order to diagnose further, you need to fix the KNOWN problem, and see what happens. It may be as simply as replacing the pump, then again, other stuff may have deteriorated when it was just sitting for four years.
Trending Topics
If the pump doesn't run, verify you are getting power back to it. (if you can.....) if it does run, see what you are getting for fuel pressure. If pressure is decent, disconnect the fuel line, and see just what the pump is pumping.... may not be gas at all.
Here's the far (!!!) simpler answer I was looking for. After much thought, I simply connected the fuel pump wires to a 14v motor (or 12v light? VOM? etc.?) sitting on my front passenger seat, turned the ignition key to "ignition," and listened to the motor run, thus verifying that I DID have the power back there, and that the fuel pump WAS the problem.
Maybe this will help someone else... i.e., BEFORE you go through the pain of jacking, draining, disconnecting & removing multiple fuel & fill components, breaking rusted tank mount bolts & straps, fighting with a rusted pump lock ring, etc.
