Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
84 Daytona Turbo Starter issue I think
Old Aug 10, 2019 | 11:41 AM
Montaquilla's Avatar
Montaquilla
Default 84 Daytona Turbo Starter issue I think State Police scared it
New computers battery cleaned connections got rid of all the codes except for 1-1 and 1-2 which is normal Turn the key relay clicks and that's it ? New relay Starter is only 2 years old and did turn over once but was a no start when I just had push started and rolled around the block a few times ? All started when I got pulled over by State Police He gave me a break but had to push start me ! Did he scare the car to never turn over again ? Can't keep push starting this Original owner and twice as old !
Old Aug 10, 2019 | 12:07 PM
If you bypass the relay with a jumper wire, will the engine turn over?
Old Aug 10, 2019 | 12:12 PM
Montaquilla
Not exactly sure which terminals to jump ? Tried a few ground wires that had no effect Hesitant to try without knowing exactly what to jump ?
Old Aug 10, 2019 | 12:15 PM
30 to 87 I believe. Keep in mind, there are likely two wires coming in that have power...... one is to control the relay, the other is power feed for the solenoid. That one will be larger...... don't use the little one to feed the solenoid, the results wouldn't be pretty.
Old Aug 10, 2019 | 12:30 PM
Montaquilla
30 87 ? I don't have much for schematics but got Brown Yellow Stipe which is ground to trans Not sure what the yellow wire is and the Red and Brown have power going thru the relay but Not sure if power is making it thru the wires Floor jack failed me so I'm not so sure about what the connections at the starter are getting Getting ready to ship it out to local mechanic as my Mechanic retired and moved to the woods ! Also I worked on harness design for Essex which became United Technologies Auto group So my ego is taking a hit !!! I should know this !!
Old Aug 10, 2019 | 03:47 PM
I don't have schematics for one of those either. But, relays are pretty standardized. Pull up an image of relay pin-out, they are all pretty much the same.
