Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
turbo question
Old May 6, 2004 | 03:05 AM
MyrlieGirl's Avatar
MyrlieGirl
Default turbo question
I kind of feel odd not knowing this, I think I did know at one point...
But I know Dodge used at least two different turbos on the Daytonas. My own Pacifica has what they called the Turbo 2. Does anyone know what turbos went with each year--etc?
This is kind of random so I apologize, but I really liked the Turbo 2 and may be taking on a new Daytona (mine is just too out of shape for me to bare with I think). So that's why I ask.
Old May 6, 2004 | 03:20 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: turbo question
I thought all Pacifica's came with the 2.2L Turbo I's. Does your's have an intercooler next to the radiator on the drivers side with a hose on top going into the air box? I'm not doubting you, I'm just questioning my own knowledge, I've never had any experience with a Pacifica.[sm=smiley24.gif]
The 2.2L Turbo I's were avaliable from '84-'88 I believe.
The 2.2L Turbo II's were avaliable from '87-'90.
The 2.2L Turbo III's were avaliable from '91-'93.
Then there's the 2.5L Turbo from '89-'92 I believe.
Old May 8, 2004 | 04:15 AM
DARKSUN's Avatar
DARKSUN
Which turbo was best for performnace and reliability?
Old May 8, 2004 | 12:01 PM
71RoadRunner
The Turbo II's. The Turbo I's and 2.5L Turbo's were non-intercooled, so they were less reliable. And the Turbo III's had head problems. My Turbo II Shelby Z went 200,000+ miles before any problems occured, and then it wasn't turbo related, it was a wrist pin. The 2.2L Turbo II is the second most powerful and by far the most reliable, as it is intercooled.[sm=smiley20.gif]
Old May 11, 2004 | 12:31 AM
87Indy500's Avatar
87Indy500
From 1984 thru 1987 Chrysler used a Garrett turbo on all 2.2's. Starting in 1988 the "new" blow thru design 2.2 & 2.5 turbo I models got a Mitsu. made turbo (TOE4). After 1987 the only models that got the Garrett's where the TII, TIII, and TIV with an intercooler (i.e. Shelby Z, Shadow & Daytona VNT, Spirit & Daytona R/T, and anything offered by Shelby except the 1988 CSX-T which got the Mitsu Turbo)
The Mitsu turbo is a good solid unit and spools up allot faster than the Garrett because of its smaller size, but it has problems with spiking at high boost settings. The Garrett is a proven unit and holds steady boost even upwards of 20+ lbs. The Garrett is the best of the 2, but it all depends upon how much boost you are planning on running. If stock boost with a fast spool-up gets your rocks off, a Mitsu maybe the way to go. But if you need a bigger kick in the rear, then the Garrett may be what you want to reach for.
Old May 11, 2004 | 09:36 PM
snappyjr's Avatar
snappyjr
So if I follow this right, my Daytona ES is a turbo I set-up... so that would meen non-intercooled. But if I did want to intercool the engine, could I use a generic kind of set-up and fabricate mounts to put the intercooler in the front of the radiator? And would it be feasable to run a medium sized intercooler on my car with stock boost?
Old May 11, 2004 | 10:11 PM
87Indy500's Avatar
87Indy500
ORIGINAL: snappyjr
You should have no problem intercooling your car and should be fairly easy to do since your Daytona is already a "draw thru" design. You just need to fab up some custom stuff (intercooler $ plunbing) to do it, or get an 87 and up Shelby Z or Labaron GTC radiator and intercoller combo w/plumbing that would be a direct bolt in peice.
Old May 12, 2004 | 09:31 AM
71RoadRunner
Yep, or contact Forward Motion for an add on intercooler kit for the non-intercooled turbo cars. Here's a link to them: http://www.forwardmotioninc.com
Old May 12, 2004 | 08:13 PM
87Indy500's Avatar
87Indy500
Another good place to visit is www.fwdperformance.com . If they don't have what you need....no one does
Old May 13, 2004 | 04:21 AM
71RoadRunner
Thanks for the link 87Indy500, I've never been there before.[sm=smiley20.gif]
