Won't start on hot days
Old May 7, 2008 | 09:41 AM
meetch12's Avatar
meetch12
Default Won't start on hot days
My 2000 neon will not start on hot days...no crank, but I get power to dash. Ignition switch has been replaced. This problem only happens when the car sits in the sun on warm days. Problem started happening last fall...had no problems all winter. Now with the return of warm weather it is happening again. Any Ideas?
Old May 7, 2008 | 10:27 AM
blackflame's Avatar
blackflame
Default RE: Won't start on hot days
huh...interesting. Is there a possibility your battery needs cleaning or replaced?
Old May 7, 2008 | 10:30 AM
meetch12's Avatar
meetch12
battery, starter, starter relay all checked okay. I am thinking it may be the drive post between the key and switch is worn out. I am at wits end.
Old May 7, 2008 | 11:17 AM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
Wow I never heard of this. I tried Google but couldnt find anything. How is your air filter? Maybe its not breathing right.
Old May 7, 2008 | 11:30 AM
meetch12's Avatar
meetch12
Nope.. It's not even cranking.
Old May 7, 2008 | 03:28 PM
inthewerks's Avatar
inthewerks
is it an auto tranny? if it is, put the car into neutral, then with foot on brake, try to start the car. if it starts, your tranny needs an adjustment for when its in park.
Old May 7, 2008 | 05:45 PM
cruzchopper's Avatar
cruzchopper
I had a acura integra that did the same thing. The problem was the fuel pump relay.After my brother fixed it the problem never came back.
Old May 7, 2008 | 09:24 PM
KARR's Avatar
KARR
Welcome cruz.
Old May 8, 2008 | 02:00 AM
inthewerks's Avatar
inthewerks
fuel pump relay? hey meetch, thurn the key to the acc position right before the engine is supposed to crank. with your door open, you should here a high pitched whining noise. if you hear it, your fuel system relay and pump are working fine. if you dont, then start with the relay and work back to the fuel pump. its cheaper that way.
Old May 8, 2008 | 02:40 AM
Adionik's Avatar
Adionik
ORIGINAL: KARR
Were you being serious?
