Won't start on hot days
Old 05-07-2008, 09:41 AM
meetch12's Avatar
meetch12
meetch12 is offline
Default Won't start on hot days
My 2000 neon will not start on hot days...no crank, but I get power to dash. Ignition switch has been replaced. This problem only happens when the car sits in the sun on warm days. Problem started happening last fall...had no problems all winter. Now with the return of warm weather it is happening again. Any Ideas?
Old 05-07-2008, 10:27 AM
blackflame's Avatar
blackflame
blackflame is offline
Default RE: Won't start on hot days
huh...interesting. Is there a possibility your battery needs cleaning or replaced?
Old 05-07-2008, 10:30 AM
meetch12's Avatar
meetch12
meetch12 is offline
battery, starter, starter relay all checked okay. I am thinking it may be the drive post between the key and switch is worn out. I am at wits end.
Old 05-07-2008, 11:17 AM
KARR's Avatar
KARR
KARR is offline
Location: In a Lucid Dream. But now I want my life back.
Wow I never heard of this. I tried Google but couldnt find anything. How is your air filter? Maybe its not breathing right.
Old 05-07-2008, 11:30 AM
meetch12's Avatar
meetch12
meetch12 is offline
Nope.. It's not even cranking.
Old 05-07-2008, 03:28 PM
inthewerks's Avatar
inthewerks
inthewerks is offline
is it an auto tranny? if it is, put the car into neutral, then with foot on brake, try to start the car. if it starts, your tranny needs an adjustment for when its in park.
Old 05-07-2008, 05:45 PM
cruzchopper's Avatar
cruzchopper
cruzchopper is offline
I had a acura integra that did the same thing. The problem was the fuel pump relay.After my brother fixed it the problem never came back.
Old 05-07-2008, 09:24 PM
KARR's Avatar
KARR
KARR is offline
Welcome cruz.
Old 05-08-2008, 02:00 AM
inthewerks's Avatar
inthewerks
fuel pump relay? hey meetch, thurn the key to the acc position right before the engine is supposed to crank. with your door open, you should here a high pitched whining noise. if you hear it, your fuel system relay and pump are working fine. if you dont, then start with the relay and work back to the fuel pump. its cheaper that way.
Old 05-08-2008, 02:40 AM
Adionik's Avatar
Adionik
Adionik is offline
ORIGINAL: KARR
Were you being serious?
Quick Reply: Won't start on hot days
