chrysler concorde help
My next door friend who is 66 year old widow, car stopped going down the road, they couldnt get it started, they ran the battery dead. so when i came in for the weekend i was ask to look at it. i have checked fuel and its got 53 pressure on it when you test it, replaced the old camshaft position sensor. i check all the volts to them and they are showing 4 but my haynes repair manual said it should have 5. Now i looked at the fuse and relay box under hood i have no power to the fues that is 10 amp pcm, and no power the the 20amp inj/coil or to the 20amp 02 ssr. can someone please help me trying to. i check power to the coil and the plugs and no spark at all will turn over sprayed start fluid in it but didnt even try to start. PLEASE HELP ME HELP THIS LITTLE LADY.
THANKS FOR ANY HELP.
MICHAEL74501@YAHOO.COM
update!
OK the timing belt broke. replaced it and there is no power to the fuse and relay center for the fuse (v) 10amp pcm, (s) 20amp inj/col, (t) 20amp 02 ssr. i checked thme with a 12 volt. tester and they show dead.
