Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Tire Pressure?
Old Oct 10, 2010 | 01:11 AM
First SUV's Avatar
First SUV
Default Tire Pressure?
Any suggestions or recommendations for a good highway tire pressure for the 17 inch P225/65R17 BSW A/S Touring Tires?
I have never had Asian tires before and not sure how much over Factory recommendations I can safely run.
When I picked the car up from the dealer they had set them to 40 PSI F/R.
Old Oct 11, 2010 | 08:53 AM
HammerZ71's Avatar
HammerZ71
As a rule of thumb, I set my tires at 80% of the maximum rated cold tire pressure as marked on the tire. This gives the best possible combination of soft ride, handling and fuel economy...
Old Oct 11, 2010 | 01:53 PM
Laomi's Avatar
Laomi
The proper cold tire inflation pressure is listed on the
driver’s side B-Pillar.
Old Jan 14, 2011 | 05:45 PM
rynosims's Avatar
rynosims
Too bad the service people can't read that. When we bought our Journey, they had serviced the tires to the max pressure the tire said, not what the sticker said. So, instead of 32 or 34 (can't remember), they had 46 PSI in them. Dumb asses.
Old Jan 19, 2011 | 03:38 PM
First SUV's Avatar
First SUV
Default Recomended is too low
My cars recommended pressure for the P225/65R17 BSW A/S Touring Tires is 32 PSI. That is fine if you want a cushy ride and poor gas mileage and cornering. When I did a temperature scan of the tread when set at 32 psi I got a 25 to 30 degree increase at the sides of the tread over the center. this indicates that the sides are carrying more load than the center. Front tires are worse than rears.
Now I am running 36 in front and 34 in the rear and it seems to be much better. Have not done a temperature scan at this pressure, but my highway MPG is up to 26.
Old Jan 19, 2011 | 10:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
I run all my cars and truck at 35psi.
Old Apr 28, 2011 | 07:55 AM
bloom08's Avatar
bloom08
34 should do good to u. u can't inflate more than that.
Old Apr 28, 2011 | 01:50 PM
First SUV's Avatar
First SUV
Default I like 36/35
I have been running 36 front and 35 rear for last 4 months. Gas mileage is better and so is handling the mountain roads. I think this is going to be my full time setting loaded or not.
I like the feel much better than when I was at 32/33
Anything under 40 cold should be fine, though 40 will make you think your riding on solid metal wheels.
