Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Fog Light bulb listed doesn't exist
Old 07-12-2011, 03:23 PM
Kandmeat's Avatar
Kandmeat
Kandmeat is offline
You can get HID's now easy and many other complete set ups with glass and plastic housings included to replace exact fit from factory. I will include a link or two at end.
The actual bulb from factory in the journey is a 24w bulb. The bulb is a H16 or 9009.
http://www.ahwooga.com/detail.asp?id=129156
http://www.drivewire.com/vehicle/dod...ney/fog-light/
http://everythingcarparts.com/09_10_...ps_Chrome.html
http://www.etrailer.com/Lights/Putco....html?feed=npn (these are what i use)
http://www.amazon.com/Nokya-9009-H16...0498423&sr=8-1
There are more and more options weekly online. Some may want running boards that don't suck also, check these links out for those, this is the only one that I have found anywhere with my research that does not look like a truck or 4x4.
http://www.runningboardwarehouse.com...2009-2009.aspx
http://www.runningboardwarehouse.com...2008-2009.aspx
Old 07-12-2011, 03:46 PM
Kandmeat's Avatar
Kandmeat
Kandmeat is offline
Cool 2009-2011 Dodge Journey Fog Lights
There are far more options on the market now than used to be. The bulbs that replace the fog lights are H16 bulbs or 9009 bulb. I will provide some links bellow for items. The factory bulbs are listed as just under 24 watts and are not the easiest bulbs to reach, so you should be prepared to unfasten some of your lower fairing on the front of the Journey just in front of the front wheel to access the bulbs correctly.
Here are some complete replacement options.
http://blinglights.com/shopbling/sto...&idCategory=64
http://www.blinglights.org/products/...%7B47%7Dt.html
These are the bulbs links. There are Led bulbs available (which are not quite as bright as incandescent bulbs) from Putco.com, just search for them on Amazon.com This first link is where you can search for led bulbs to fit the Journey.
http://www.putco.com/products.cfm?action=lightingview
This is two links to the Best two running board options available for the Journey, pass this along to whoever you need to.
Quick Reply: Fog Light bulb listed doesn't exist
