check engine comes on alot!
Old Sep 12, 2007 | 03:52 PM
capnhook77's Avatar
capnhook77
Default check engine comes on alot!
Ive had my 2005 se magnum in 9 times because my check engine light comes on.They found a leak and fixed it, then they sais it was a fuse. I drove it long distance for 3hrs and it comes on every time, but not in the city. Has anybody had this problem?
Old Sep 12, 2007 | 07:54 PM
65standard's Avatar
65standard
Default RE: check engine comes on alot!
what is the code that comes up?
Old Sep 13, 2007 | 12:05 PM
Free_Style's Avatar
Free_Style
Mine too. AirBag,thremostat,ESP system. Rear end leak, Locked up rear end. Trans Leak. Seat bracket broke, Trim falling off. Trans somtimes does not want to go into gear.Clear coat chippingon wheels. Valve ticking. A/C somtimesdoes not work on highway.Dodge makes eye catching auto's but they will need to work on quality and then I will continue to buy. Also trade in value sucks. 13k for an 05 R/T loaded. Sorry, just upset that a 35k is worth that little 3 years later.
Old Sep 13, 2007 | 04:25 PM
2005 Magnum R/T Hemi's Avatar
Free Style,
Tell us how you REALLY feel....
Old Sep 13, 2007 | 07:09 PM
capnhook77's Avatar
capnhook77
code? the little check engine light on the dash, underneath the gas gage.
Old Sep 13, 2007 | 08:38 PM
65standard's Avatar
65standard
if ever the MIL lamp comes on, there is a diagnostic code stored. to get the code do this:
Get in the car, close the door. Perform the following steps fairly quickly (less than 3 seconds) :
Turn key to ON
then back to ACC
then to ON
then back to ACC
then to ON
If there are any stored codes, they will appear immediately, in place of the odometer. For instance an "INTAKE AIR TEMPERATURE SENSOR CIRCUIT HIGH" error will set a code of P0113.
let me know the list of codes that come up.
Old Sep 13, 2007 | 10:16 PM
capnhook77's Avatar
capnhook77
I did that exactly, nothing showed up. It showed like 5 lines, and then said-done- and that's it. I tried several times, but nothing.
Old Sep 14, 2007 | 06:12 PM
65standard's Avatar
65standard
let me get this straight. your check engine light is on or was on and there are no codes stored???
i never heard of this. let me try to find out why.
Old Sep 15, 2007 | 05:30 PM
capnhook77's Avatar
capnhook77
Right, nothing comes on, I did over and over and nothing comes up, I did the last couple of days and still nothing.
