transmission leaking
Old Dec 27, 2007 | 08:32 AM
STIguy's Avatar
STIguy
Default transmission leaking
Hey guys and gals.....
I noticed a spot on my garage floor, and it seemed to be transmission fluid. Doing a search on here, this seems to be a common problem. I've got a '06 Magnum R/T with 9,200 miles and dropped it off last night at the dealer for repair.
Can anyone tell me what the normal fix on this problem is and how long it takes ??? Is it a new gasket or rings or something along that line ??
Thanks.
Old Dec 27, 2007 | 12:40 PM
2005 Magnum R/T Hemi's Avatar
Default RE: transmission leaking
STI,
If you are lucky it is just the O-Ring. It is a simple fix and you should have it back the next day... Let us know how it went.
Old Dec 31, 2007 | 06:51 PM
STIguy's Avatar
STIguy
Well, the dealer said it was called a Transmission Cup Plug......replaced it, under warranty of course, and had it ready along with an oil change in about 4 hrs. Can't beat that !!!!
He said this was a common problem with hemi-equipped vehicles.......
Old Jan 8, 2008 | 04:21 PM
JH Magnum's Avatar
JH Magnum
Hey STIguy,
I was just reading an article from Canadian Driver and it mentione the leaky transmission. This is the link to the article, unfortunatly it tells where it is leaking but not how to fix it
http://www.canadiandriver.com/articl...5-07magnum.htm
JH
Old Jan 8, 2008 | 05:30 PM
MagnumBrit's Avatar
MagnumBrit
I just noticed mine '06 was leaking last night too and this morning the light came on :/
Booked it in at the dealership for first thing tomorrow, hopefully it's something simple.
Old Feb 8, 2009 | 11:52 AM
Al Briggs's Avatar
Al Briggs
Default Transmission Leak TSB #'s????
I found TSB 2100205 that deals with fluid wicking around the pan, but can't find anything about the O-rings. Does anyone have the TSB number or other documentation reference the I can take to the dealer?
Old Feb 9, 2009 | 09:06 AM
Carolina Magnum's Avatar
Carolina Magnum
Yup, gotta take my 2006 SRT with 5350 miles in this week; same problem!
Old Feb 9, 2009 | 06:59 PM
65standard's Avatar
65standard
it seems that nearly ever nag5 trans has these swollen o-rings that seep fluid.
Old Feb 12, 2009 | 09:15 PM
transguy37's Avatar
transguy37
Hello,
This is a common problem with the Nag1 or 722.6 as Mercedes calls it. On the passenger side at the bell housing, is the electrical plug for the trans. It has 2 O-rings on it to seal the connector coming out. Just be aware of this problem. Just out, Mercedes came out with a 722.9, this is the 7 speed version. They are looking for Dodge to pick this one up too and call it the Nag2.
Old Feb 12, 2009 | 09:18 PM
transguy37's Avatar
transguy37
Oh yea, all the Mercedes are having the same leaking problem too.
