side mouldings
Old Feb 17, 2005 | 02:42 PM
kenowell's Avatar
kenowell
Default side mouldings
How do you take off the side mouldings without damaging the paint?
Old Feb 17, 2005 | 03:18 PM
MikeEast's Avatar
MikeEast
Default RE: side mouldings
Side moulding comes off the same way the badges do - get some fishing line and some good gloves and just 'saw' your way along behind it.
Then use something like goo-gone or just your fingernail and rub off the black sticky goo that's left.
Tedious, but it doesn't damage the paint at all - unless you are unlucky enough to have a ghost image left behind, where the paint actually discolored a bit where the mouldings prevented it from changing with the rest of the paint.
Grinner sure do have his troubles :-(
Mike
Old Feb 17, 2005 | 04:35 PM
kenowell's Avatar
kenowell
Thanks for the info mike
Old Feb 17, 2005 | 10:19 PM
grinner's Avatar
grinner
I just peeled em off then used my finger n thumb to rub off the unwanted/un asked for hooha left over.
Did it on two magnums now and doing it in the warm sun is much easier.
As long as the paint has not been damaged by those bogus and quite useless moldings, your all good.
Otta take ya less than an hour.
why they wanna depreciate the car with these is beyond me but then, we're talkin about the same folks who scew on those fugly roof racks too.
Putting retirement-aged white dudes in charge of these decisions is pretty stupid on the part of Dodge.
Same guys who gave the thumbs up to the design of the new charger, I'm sure.
I've spent more time and money removing dumb stuff off my car than I have putting cool things on it so far.
Old Feb 17, 2005 | 10:32 PM
Ram Job's Avatar
Ram Job
I found both the fishing line and the old finger and thumb method work well, also, I use one of those soft plastic bondo spreaders work well. One tip, I usually heat the moldings up with a hair dryer to soften the adhesive, or park in direct sun light for a few hours.
Old Feb 17, 2005 | 11:46 PM
Lyle SXT's Avatar
Lyle SXT
Each of us is certainly different. I'll surely agree on the 'fugly factor' of the roof rack. But I quite like the moldings. I've looked at quite a few photos so far, and really think it looks like something's totally missing when they're removed.
My side moldings will stay when I get my car.
Cheers,
Tilt
Old Feb 18, 2005 | 01:51 AM
mamas magnum's Avatar
mamas magnum
Wife drives the car parking lots 'nuf said
Old Feb 18, 2005 | 07:04 PM
Bobs05RT's Avatar
Bobs05RT
I think the cars without the mouldings gives the vehicle a smooth look but also makes it look slab sided. I'll keep the mouldings.
Old Feb 20, 2005 | 04:14 AM
RobAGD's Avatar
RobAGD
There is also something that body shops use on a air Drill that looks like a huge rubber eraser. My dad does body work and uses them all the time to take molding goo off doors without wrecking the paint. You can BURN the paint though so be carefull.
Use a hair drier or a heat gun on a lower setting and take your time, if you rush you will mangle something.
-R
