Question re tow package
Old Mar 13, 2005 | 12:15 AM
Hoefi's Avatar
Hoefi
Default Question re tow package
Hooked up my trailer today and drove around. The back end didn't pump up. Does the tow pack come with self-leveling shocks, I thought it does.
How can I confirm the tow pack on the VIN number?
Thanks in advance.
Joe
Old Mar 13, 2005 | 01:35 AM
Black RT's Avatar
Black RT
Default RE: Question re tow package
If ( tow package) was ordered from factory when magnum was built It should have the self-leveling shocks, cooler,trailer light wiring harness,tow hitch. I had dealer installed tow hitch and wiring harness for trailer lights on my Magnim RT.Some one on this forum said those self-leveling shocks cost several hundred dollars each.
Buddy in KY
Old Mar 13, 2005 | 01:57 AM
stboden's Avatar
stboden
The owners manual states, the vehicle will level itself over the first couple of miles of driving. You would not even notice it leveling itself. I have the tow package also, just need to get the hitch. I still can't believe it didn't come with the package.
Old Mar 13, 2005 | 03:48 AM
Bobs05RT's Avatar
Bobs05RT
The factory tow package only includes the self leveling shocks and a heavy duty cooling system. That's it. The hitch, wiring are to be bought from the dealer and then installed to be able to tow.
ORIGINAL: Black RT
Buddy in KY
Old Mar 13, 2005 | 06:54 PM
obiwan's Avatar
obiwan
I have the self leveling shocks and lowered my mag. I had an offer to trade straight across until I found out the self leveling shocks cost $270 each and the non-levelings run $80.
Old Mar 14, 2005 | 12:20 AM
Hoefi's Avatar
Hoefi
It was a factory ordered with tow pack. It did not come with wiring harness (all my previous Caravans did when I order the tow pack). On the Caravans, after driving a few miles, the rear would come back up to slightly higher than level (the chassis has a noticable rake to it even without the equalizer bars). With the Magnum now, the whole chassis slopes backward (tested the car again today with the equalizer bars and it's still running low). I wonder if it's possible that they forgot to install them on the assembly line? Are there any ways to identify these shocks compare to the regular ones?
Joe
Old Mar 15, 2005 | 07:39 PM
DB Cooper's Avatar
DB Cooper
If you remove a rear wheel, you'll see a sticker with "Sachs". They manufacture the self-leveling shocks. Also, the rear springs are a little different. Mine has an "AWD" sticker on it. My RT is RWD only.
Old Mar 18, 2005 | 06:09 PM
strippedhemi's Avatar
strippedhemi
Mine dont have the air shocks, has factory reciever hitch. I tow my small car trailer with it as is with no problem.
