06 Magnum Transmission Input Speed Sensor
Old Jan 30, 2010 | 02:14 PM
2006MagnumSXT's Avatar
2006MagnumSXT
Default 06 Magnum Transmission Input Speed Sensor
Hello everyone,
Appreciate any advice on this. I have an 06 Magnum SXT and I had an issue when starting the car and going into reverse the gear jumped and then I was driving and I could not get the car over 30mph. I pulled over, and turned the car off and on and it was ok and then the engine light went on.
I went to a dealer to determined what the issue was, and I was told it is a Transmission Input Speed Sensor, and the estimate was about 600.00! First off, I wanted to ask is this price reasonable, and also, is it good to ge ta 2nd opinion on a reading or are they pretty accurate?
Thanks for any help
Old Jan 30, 2010 | 09:55 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you know which transmission you have? 42RLE or the NAG1 trans. If it the 42RLE, then it to much money. The sensor maybe 52.00 and then the labor. If you have a NAG1 trans, then that maybe in the ballpark. The valve body has to come down to replace the solenoid and both input sensors.
Old Jan 31, 2010 | 08:52 PM
2006MagnumSXT
Many thanks for your reply...I am not sure what transmission I have...I do not know much about this subject, is there a way I can determine this based off the VIN? I checked my Owners Manual to no avail....any help is very appreciated!
Old Jan 31, 2010 | 09:16 PM
master tech
If you have 2.7 or 3.5L, you may have the 42RLE trans. And if you have a 5.7L Then its a good chance you have the NAG1 trans.
Old Jan 31, 2010 | 10:32 PM
2006MagnumSXT
Thanks again! I do have a 3.5L High Output, so that pretty much means I have the 42LRE?
Old Jan 31, 2010 | 11:38 PM
master tech
Look under the car and look at the transmission pan, if the pan is silver in color. That would be a NAG1 trans. If the pan is black and has large sq pan,then its a 42RLE trans.
Old Dec 10, 2011 | 09:38 PM
sheriball's Avatar
sheriball
Default Need Help!
HI are you online right now?
sheriball's Avatar
sheriball
Hi are you online right now?
