2006 Dodge Magnum AWD Brake Rotor Problem
Magnum AWD front rotor problem
At 12,000 miles, my 2006 Hemi magnum was showing symptoms of front rotor runout. At 26,000 miles they became very bad, I replaced the rotors and the pads. The rotors were total junk, almost falling apart in my hand.
Since the dealer wanted megabucks for the job, I did it myself and used parts from Auto Zone. My thinking was that the factory rotors were not very good so the aftermarket could not be any worse. The dealer service manager felt that the car may have been in inventory for a long time, and the metallic pads rusted into the rotors. So I used ceramic pads.
Now at 28,000 miles, the runout is back. The steering wheel shakes violently when braking from over 50 mph. Replacing rotors every 2000 miles could get expensive.
There is something inherent in the design of this braking system that is not right. Since Chrysler has been offering disc brakes for about 50 years, they should have it right by now.
I just had ceramic pads put on car (free pads but labor is 200.00 so I stop there)
Again, my cross drilled rotors after 15k warped all around the car. Each rotor weighed as much as 2 stock rotors and cost about $700.00 for 4 cross cuts for AWD Magnum.
The factory rotors were warping after 2,000.
I have other cars (I have owned over 100 cars in my life) and this is only happening on the Magnum.
Since Fiat took over I do not think that they want to be bothered with pre Fiat made cars.
My sister has an 08 Charger with same problem. I know at least 6 other people with Chargers, Magum, 300's and all rotors have warped.
I find this to be BS!
Jack
Magnum 2006 3.5 AWD
P.S My gear lever was recently stuck in park for almost 2 weeks till I found an out side vendor that made the part in aircraft aluminum and shipped it to me.
Chrysler/Dodge is backed up on the part 7-9 months. It happens to a lot of people with these cars. Google it and be prepared.
My 77 Corvette is on a set of rotors with 40k that I put on it and with a dial gauge they all are straight as day one.
Just did new pads
Interesting thing here, very interesting. Someone above mentioned the pins are sticking, and that was my thought from post one all the way through. Why has no one other than the one other person either looked into this to confirm or rebuke his statement? Once my mag starts this(and from all posts it will) that will be high on the list.
My wife has a 300AWD that does not exhibit these same findings, it has roughly 52k on the odo.
Magnum Rotor followup
When my replacement rotors from Autozone failed in 2000 miles, I removed them and found them to be cracked and warped. I replaced them with AutoZone's heavy duty rotors, much more expensive. I also went out of my way to clean the pins thoroughly. Problem is solved, no more braking problems. The downside is that I don't know if Autozone is still offering these heavy duty rotors anymore.
