Valentine1
Old Dec 10, 2005 | 04:37 AM
Flash Gordon's Avatar
Flash Gordon
Default Valentine1
Anyone hard wire a Valentine1? How did you do the install?
Old Dec 22, 2005 | 01:52 PM
NJRT's Avatar
NJRT
Default RE: Valentine1
I hardwired my Valentine 1 and use the suction cup mount above and to the left of the mirror. I tucked the wiring under the headliner to the A pillar. I then partially removed the gray/black door & A pillar weatherstrip for access and put the wire under the A pillar, along the bottom of the dash and hard wired it into the cigarette lighter in the dash below the radio. Even though my vehicle had the smoker's package, the power for the lighter still cycles on and off with the ignition key.
Note: I needed to wrap the wire with some foam tape to prevent rattling in the headliner area and tie wrap the wire to the rear view mirror stem to keep the wire from pulling out of the headliner and letting the unit fall onto the dash if the suction cups come loose.
Old Dec 29, 2005 | 03:23 PM
Flash Gordon
Do you have any pictures? Thanks for the details.
Old Dec 31, 2005 | 02:28 PM
NJRT's Avatar
NJRT
What type of pictures are you looking for? I didn't take any during the install and at this time all that's visible is the power wire coming out from under the headliner by the mirror. I might be able to be a little more descriptive with the install process if that would help.
Old Jan 12, 2007 | 03:54 PM
ukchris's Avatar
ukchris
Wire up the V1, put it as far behind the mirror as you can without obscuring the rear sensor then put the display in the mirror!
Old Jan 20, 2007 | 01:36 PM
magnum_ocd's Avatar
magnum_ocd
ok, i really want to know how you did that...
Old Jan 20, 2007 | 01:58 PM
ukchris's Avatar
ukchris
Well, I can't tell you all the steps involved as the process is pretty detailed but the remote display for the V1 is mounted inside the mirror and the mirror coating is removed to allow it to show through. I could also etch it to look more like a compass if you wanted a more stealthy display, simething like this:
Chris.
Old Jan 21, 2007 | 07:09 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Thanks for sharing ukchris! The why you installed the V1is slicker than snot.
Old Jan 22, 2007 | 03:04 PM
RT 2 NV's Avatar
RT 2 NV
the mirror option is sweet. nice job. ive seen others in the dash by the speedo too.
