Manual Transmission Conversion?
Old Sep 1, 2004 | 08:13 PM
NeonDriver01's Avatar
NeonDriver01
Default Manual Transmission Conversion?
I have heard that it is possible to convert a auto tranny to a standard. Do they sell conversion kits to do this? if so where can i find one? its for a 2001 dodge neon se. thanks!
Old Sep 1, 2004 | 08:16 PM
LoNeWuLf's Avatar
LoNeWuLf
Default RE: Manual Transmission Conversion?
Isnt that expensive to do?
Old Sep 1, 2004 | 08:17 PM
casper's Avatar
casper
you are probally better off going to the junk yard and getting a mtx that was rear-ended, or totaled or somethin like that. I don't believe they make a conversion kit. I have seen on ebay people that put together all the stuff you need to convert and sell it.
Old Sep 1, 2004 | 08:19 PM
casper's Avatar
casper
under a $1000 and you can turn around and sell the atx when your done. my buddy did it on his 626, took a lot of work but wasn't that expensive.
Old Sep 1, 2004 | 08:20 PM
LoNeWuLf's Avatar
LoNeWuLf
wow
thats not too shabby at all..
Old Sep 1, 2004 | 08:21 PM
sushi423's Avatar
sushi423
Acording to mechanics ive talked to converting a auto tranny to a manual is a son of a bitch to do, but still manuals kick ***.
Old Sep 1, 2004 | 08:26 PM
casper's Avatar
casper
are you planning on going turbo? If so you might want to stay auto. You loose boost presure when you shift manually.
Old Sep 2, 2004 | 03:53 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
ORIGINAL: sushi423
You sure about that?
<----Is an ATX and has no problem helping out other ATXers.
<---- Also has a race built ATX, If you want pointers, lemme know. There's a misconception about MTX's I could clear up. Neither ATX or MTX are better than the other, but they do have their advantages over the other and flaws.
Old Sep 2, 2004 | 01:33 PM
sushi423's Avatar
sushi423
i wouldnt do it
Old Sep 2, 2004 | 02:19 PM
Altima_wb's Avatar
Altima_wb
ORIGINAL: Crazy Squee
I'd be interested in learning more about your setup, we have been back and forth about swaping to mtx in project neon. but seen as the problems that we were having seem to have disapeared with a filter and fluid change, I am kinda lean toward sticking with the auto. Plus we plan on going turbo so auto is a much better choice.
On other note swaping from atx to mtx in a neon is hella easy. With knowlegeable people and the proper tools and all parts on hand it can be done in about 4 hrs. (Unless you plan on drinking then add about 2 days ).
