Horrible Gas Mileage
Old Sep 16, 2004 | 08:03 PM
Neonsxt0486's Avatar
Neonsxt0486
Default Horrible Gas Mileage
I have a 2004 Dodge Neon Sxt 5-Speed with a Cold Air Intake and Catback with just a resonator no muffler. I'm filling up with about $18 and gettin about 190 -200 miles per tank? I know my brothers got a 1st gen that gets about 300. Is this a problem or am i bein picky. Thanx , Brian
Old Sep 16, 2004 | 08:14 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: Horrible Gas Mileage
I would say it is. I have a 2004 with basically the same things as you and I usually am around 260ish miles when I fill up, and that is filling up before I hit the first gas light. I'd check tire pressure, your air filter, probably check spark plugs, it should be getting better mileage than that even if you do drive like a bat out of hell it still should do better than that. By the way, you almost stole my name, I thought when I was lookin, "wtf, when did I post that?" Then I realized someone has almost the exact same name! Welcome aboard.
Old Sep 16, 2004 | 08:51 PM
techmanbd's Avatar
techmanbd
Mine is fully stocked and I get about 240 and that is about when the light comes on, so I could get about 260 or more if chanced it, but don't like letting it get that low. And That is driving city streets only.
ok I have a question? I don't know anything on resonators, but doesn't NOT having a muffler rob you of the back pressure you need that will make you lose some power?
Old Sep 16, 2004 | 08:56 PM
techmanbd's Avatar
techmanbd
Also, how many miles do you have on the car, one thing I noticed is my gas mileage improved big time after 1500 miles. Was told once that the PCM is designed for a break in period of about 1500 miles, then you get better performance. Before that I was getting about 200 miles per tank.
Old Sep 16, 2004 | 09:16 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
ORIGINAL: techmanbd
Exactly.
Old Sep 16, 2004 | 09:30 PM
techmanbd's Avatar
techmanbd
ORIGINAL: dustyloins
ORIGINAL: techmanbd
Exactly.
So then you are using more throttle to get more power, thus using more fuel
Old Sep 16, 2004 | 10:06 PM
TJW815's Avatar
TJW815
you hit it right on the head, When I hit a possom I ripped my muffler off and drove around ghetto style, sounded mean as all could be, but my gas mileage went to pot, i would say put some kind of high flow muffler on there to give you some backpressure, doesn't take much but the cat converter by itself isn't enough.
Old Sep 17, 2004 | 01:57 AM
sushi423's Avatar
sushi423
i heard that the second gens get worse gas miledge b/c of un nessasary gearing..or something like that.
Old Sep 17, 2004 | 02:22 AM
LoNeWuLf's Avatar
LoNeWuLf
i get about 25 mpg :-D
Old Sep 17, 2004 | 02:27 AM
sushi423's Avatar
sushi423
32 ****a
